Do 4th gens have LSD?
I need to purchase a driveshaft and they asked me if the car has LSD. Is there a number on the transmission or some other tell tale sign to look for to see if it has LSD?
Its an automatic 98 GLE
The number at the bottom that says transaxle is RE4F04V, that indicates that its an automatic with LSD, if it does not have LSD it will read RE4FO4A.
the other easy way to tell is if you go around a sharp turn and give it some gas, the inside wheel in the front will slip and spin some if you don't have LSD. If you do have it, you will have great response from both wheels aroung the corner.
found this online -
When one of the drive wheels begins to slip, the limited-slip differential automatically sends a greater proportion of the engine's power to the wheel that is NOT slipping. Limited-slip doesn't reduce the power applied to the drive wheels, but instead redistributes it.
Originally Posted by Ceasars Chariot
found this online -
You read my mind....hey ceaser is your car leaning in the picture?
Only the 99 Maxima had the "Traction Control System" option. Learned this a few weeks ago
http://www.edmunds.com/used/1999/nis...num3.1.nissan*
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
