Fuse Question
Old Jan 10, 2004 | 10:55 AM
palaman's Avatar
Fuse Question
I am in the middle of changing my fuel filter and when disconnecting the fuse to the fuel pump it was a 7.5A instead of a 15A fuse that was labeled on the panel.
Can someone check out the fuse panel on thier (98?) max and verify what amp fuse should be in the fuel pump slot?
What are the effects of having not enough or to much amps?
Thanks!
Old Jan 10, 2004 | 01:19 PM
CalsonicSE's Avatar
should be 15 amps.
Old Jan 10, 2004 | 05:16 PM
Matt_NZ's Avatar
Are you sure you pulled the right fuse? There is a 7.5A fuse below the fuel pump fuse, maybe you mis-counted and got the wrong one?
The fuse won't convert a higher current down to 7.5A, it'll simply blow.
Old Jan 10, 2004 | 09:22 PM
palaman's Avatar
It was a 7.5A in the fuel pump fuse because when I took it out and tried to start my car it would start and then die soon as I touched the gas.
Old Jan 13, 2004 | 07:50 AM
palaman's Avatar
Additional fuses
Also, there are fuses in all of the slots ... there are no empty slots
like the panel shows. Would they be just spares put in by the
previous owner? Since there are no aftermarkter alterations that
would require the use of extra fuses.
I guess I can just pull them out one at a time and find out if they
are needed by trial and error. Would the result be immediately
noticable?
Or would anyone know why my fuse box would be wired different
than the fuse panel shows??
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 16, 2015 12:17 PM
conansriver
Sep 11, 2015 10:26 AM
jwright36
Sep 8, 2015 11:45 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
