installation fee for springs, shocks, dustboots, camber kit, and wheel alignment.
I called two local places and they both said $230 on installation alone. Is this a reasonable price? Personally, I'd rather install them myself, but last time I attempted, the nuts in the center of the strut mount wouldn't come off. When I try to unscrew it, the whole strut spins with it. Anyone got anything that can remedy this? Please help me out~! Thanx~!
don't remove the center nut with out a spring compressor on the spring....or you may get hurt when the spring trys to shoot out.....once the spring comprssor is installed an impact wrench makes short work of the center nut....btw most shops will charge 4-6hrs to install the suspension plus the alignment....my dealership would be 6hrsx$70 and $70 for the alignment....so $230 is not bad if you don't have the tools and place to do the install yourself...
Originally Posted by felix822
you can loosen the nut a little while the struts are on the car, then it'll be easier to take off. or use pliers and hold the middle piece while loosening the nut. worked for me.
dank4us
34
Jun 10, 2024 03:45 AM
vingodine
45
May 21, 2016 12:46 PM
95Maxi
35
Sep 2, 2015 10:37 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
