Q about my brembo drilled/slotted rotors
Old Jan 10, 2004 | 02:36 PM
JeEvE's Avatar
I got these rotors in a GD and im not sure if they are the right ones. Both are different, The boxes say 1 piece R Nissan, it is 20mm thick and the other one says 1 piece F Infiniti and it is 8mm think. The 20mm thick rotor looks like this one... http://store.yahoo.com/southwestauto...smaxbrem1.html The 8mm rotor looks the same but it is not milled in the middle, its solid and only 8mm thick. Is this right? I came across this writeup on front breaks... http://www.motorvate.ca/mvp.php/302 and the rotors look like the 20mm ones which say they are R (rear?) on the box. Can someone straighten this out for me?
Old Jan 10, 2004 | 02:51 PM
z32drifter's Avatar
sounds like you got 1 rear and 1 front....the solid rotor should be the rear....and the vented one (milled in the center) is a front...sounds like someone mixed the rotors in the boxs
Old Jan 10, 2004 | 06:52 PM
JeEvE's Avatar
I have all four rotors and wasnt sure why the thicker ones were rear. They were all in the wrong boxes then. Thanks a lot for clearing that up.
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
