Problem with Digital Climate Control-->> Please L@@k
Old Jan 12, 2004 | 12:19 PM
190hpKiLLA's Avatar
Granny Driven
My friend has a 99 Infiniti I30.
When he puts on the heat at full blast its still blows cool air and not hot.
Sometimes it works and other times it doesnt.
What can it be??
Thank you.
Old Jan 12, 2004 | 12:24 PM
ABK's Avatar
ABK
Maybe (that what was wrong with one of my friends car) the valve that opens the colant passage to heater core inside the car is not opening. It's either broken or the system motor went dead. Just an idea.
Old Jan 12, 2004 | 12:50 PM
hotmax97's Avatar
yeah that sounds like it .i'had a car that i had to take sharp right-
turns just to get it to work i'dont mean to worry you
but if that's the problem damm big bucks man good luck
Old Jan 12, 2004 | 02:03 PM
69CHARGER_RT's Avatar
Make sure that the cooling system is full.......if it becomes air bound your not going to have the correct amount of coolant in the system causing heat problems
Just a thought.....
Old Jan 12, 2004 | 02:20 PM
Kevlo911's Avatar
Kevlo for President
Change the thermostat, look in the 4th gen how to for a how to.
Old Jan 12, 2004 | 02:37 PM
mansurxk's Avatar
yeah im pretty sure hes right about that, its problaby stuck in a certain position
mikeg75
Nov 30, 2015 05:12 PM
EdRomo86
Sep 12, 2015 07:49 PM
mix master
Sep 7, 2015 08:28 PM
