Curious 4th gen vs. 3rd gen ve
Old Jan 13, 2004 | 01:48 AM
Shift_my vq's Avatar
Hey sorry if this has already been posted. I'm sure it has but I read till my eyes are numb trying to find it. And I don't have a bank acount to donate yet. So what would win stock vq or a stock ve. Both 5 spd and at the track of course.
Old Jan 13, 2004 | 06:50 AM
NmexMAX's Avatar
dot dot dot ...
Depends on too many things. Once get a bank account, you'll find plenty.
Old Jan 13, 2004 | 07:12 AM
95MaxSE's Avatar
I say that the 4th gen would win. I remember reading the C&D article in 94 when the 4th came out, and it said that the new car is better than the older one in every aspect. The only negative on the 4th gen is the NON-independent rear suspension, but that's only on paper. On the track, they (C&D) could not find any disavantage of this money-saving rear suspension. The tested vehicle was and SE 5 speed.
Sam
Old Jan 13, 2004 | 07:46 AM
dmontzsta's Avatar
Ford Only.
Sam
I think you are just guessing.
Shift_VQ it depends on many things, but I know stock for stock the VE will have the advantage the longer the race goes on.
Old Jan 13, 2004 | 07:58 AM
wariow's Avatar
the ve stock weighs around 3200 lbs while the vq weighs at 3000 something pounds and the vq has more low end torque. My friend has a 90 max 5 spd and he says my car pulls harder during lower rpm's.
My vote will be for the vq stock for stock
Old Jan 13, 2004 | 08:04 AM
NmexMAX's Avatar
dot dot dot ...
Vq + Mevi .
Old Jan 13, 2004 | 10:15 AM
Jeff92se's Avatar
I'm needing a caw
All depends. In general the VQ is probably a tick faster. Question to you. Can you drive decent?? Are the two cars functioning correctly? Don't assume both are working in peak condition because chances are ONE of them won't be.
Because even if you have a VQ, if you can't drive, you will lose to a good VE 5-sp driver.
So the slight differences aren't really revelant. Your driving skill is. Especially when you can't ask "well let's imagine I was driving both" because you can't
You can always search Yahoo or Google or whatever to get stock specifications
Old Jan 13, 2004 | 12:14 PM
maxima98vspec's Avatar
200 lbs is nothing really, and for every 100 pounds u take off ur car will be .1 second faster.... but i still think the vq would be better but i donno it the long run. And what's the bank accont for i got one, what would that do for me?
Old Jan 13, 2004 | 12:31 PM
hotmax97's Avatar
wow is hard to say ! i have both a (90 auto)& (97-5spd)both of my
cars are in very good shape "no performence mods do" both stock
the pick up in my 97 it's great but my 90 keeps p with it very will
in the long run they are pretty even .just my opinion
Old Jan 14, 2004 | 06:54 AM
NmexMAX's Avatar
dot dot dot ...
Just saw your location alb NM, hmm, I'm abit North of there, Los Alamos
And usually that's the rule of thumb, for every 100lbs, you gain ~.1 sec, but .1 is alot of distance when racing, a carlength or so . . .
Old Jan 14, 2004 | 07:06 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Battle of the Maxima 3.0's good readin'
The 4g is lighter and the VQ is torquier. But the VE with its variable valve timing and intake manifold has a slightly better top end and can give a VQ a good run on the highway or at higher speeds.
Old Jan 14, 2004 | 07:32 AM
C MAX's Avatar
i owned both cars, i had the 92 se with the 190 hp,, and it was very good on the top end.. i also owned at the same time the 1996 se five speed .. i let my brother drive the 92 and he would pull on me slightly..
i was a little shocked but they say its because the 92 have a variable
timing which gives it a lot of pep.. but after i modded the 96 oh lord...
i also modded the 92 and it was devastating also but not like the 96.
Old Jan 14, 2004 | 08:50 AM
95MaxSE's Avatar
I'm not guessing. I was just telling you what I read in the C&D's article in early 1994. You can read it yourself. Whether you believe what they reported in the article is none of my concern.
Sam
Old Jan 14, 2004 | 09:05 AM
MONTE 01&97 SE's Avatar
Yes manual to manual it will be close with the 4th gen getting out ahead and the 3rd gen VE coming back in the long run, I mean long run 85mph +. Now auto for auto the 4th gen auot would kill the VE auto,that thing was a dog off the line and just wasnt impressive. I have seen 89-94 GXE's pull on a few VE auto's to 65 mph or so, even had a tape of it a while back.
Old Jan 14, 2004 | 09:29 AM
SteVTEC's Avatar
yup, i could believe that. 4G VQ's manuals crap out very noticeably above 80 without the variable runners or timing.
Old Jan 14, 2004 | 10:41 AM
Ninos_Maxima's Avatar
be the change u want2C
Wait the 3rd gen has 2 motors right, the 160hp one and the 190hp right?
Old Jan 14, 2004 | 11:02 AM
MaximaTodd's Avatar
G
yeah 89-91 SE and 89-94 GXE all had the 160 hp while the 92-94 SE had the 190
Old Jan 14, 2004 | 12:38 PM
C MAX's Avatar
Also The 190 Hp Started In 91 In The Five Speed Only... Then In 92-94 It Was Available In Auto And Five Speed
Old Jan 14, 2004 | 01:37 PM
Jeff92se's Avatar
I'm needing a caw
The VE pulls better (stock vs stock) when the rpm gets into the higher ranges. Since 1st and 2nd is so short, the difference doesn't make itself apparent until sometime in 3rd gear. So at about 70, the VE will start gaining as both maximas wind out 3rd gear.
The VE30DE wasn't introduced until the 1992 model year. No 1991 year maximas had it.
Old Jan 14, 2004 | 03:18 PM
ivolley's Avatar
I don't think this information is accurate. The VE was not introduced until 92. From 89-91 the GXE and SE (auto and 5sp were the VG 160hp 182 ft/lbs)
MAXSE5SPD
Sep 17, 2022 04:00 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
