Crank seal Leaking/CV Boot ripped--> Please L@@k
Old Jan 13, 2004 | 09:56 PM
190hpKiLLA's Avatar
Granny Driven
My crank shaft pulley is leaking. What do I do?
A)replace just the seal
b) replace the pulley and the seal
Some people say to replace everyhting But that damn pulley is expensive and I think I should just try the seal 1st.
My CV boot is ripped So i will be changing the whole axle. When the axle comes out of the tranny What seals do I need to change because I dont want that sh*t to start leaking after its put back together.
Thank you
Old Jan 13, 2004 | 10:09 PM
Vyrus's Avatar
Are you doing the work yourself, having a dealer do it, or a private shop? You can get a UDP installed with a new seal for less than $260 at most places ($160 for Motostorm UDP and all parts needed).
If you are having the dealer do it, I would have them order the pulley, then ask the mechanic to inspect yours when it is off and the new seal is being put in. If he tells you (and it must be him, not the service manager) that it needs to be replaced, replace it.
-Cyrus
Old Jan 13, 2004 | 10:12 PM
190hpKiLLA's Avatar
Granny Driven
-Cyrus
Private shop will do it. Its cheap labor cause there is nothing to do. I would change it myself but its cold as brick here.
And It has to be a stock pulley.
Old Jan 14, 2004 | 06:22 AM
Confused's Avatar
Permanent Maxima.org Resident
if the s/c is running ok chances are its just the seal.
Old Jan 14, 2004 | 08:47 AM
meccanoble's Avatar
Sports Button FTW
only running nos ehhh
Old Jan 14, 2004 | 01:01 PM
190hpKiLLA's Avatar
Granny Driven
how do I know if the SC is ok?
I replaced AVERYhting and the same s*it. F*CKKKKKKKKKKKKKKKKKK.
Im thiking maybe the nissan filter is leaking also. I jacked up the car on one side and it looks better then before but there is oil under the filter. I'm gonna give another try with new Tee fitting and pressure unit.
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
