loud ticking noise from throttlebody
Old Jan 16, 2004 | 08:32 AM
jayanth's Avatar
Hi Guys,
My 95 max has been ticking like an old grandfather clock for the past few days.Its source is right behind the throttle body.This is an assembly which is mounted onto the TB has 3 or 4 plugs on it from sensors.Sorry i can't describe it more clearly but i think you smart guys can figure it out!
I am pretty sure about the source of this noise.
thanks,
Jay
Old Jan 16, 2004 | 09:25 AM
DR-Max's Avatar
Are you talking about this part? This is the IACV (idle air control valve).
Most people in the org have had this problem. Remove and disassemble the IACV using this method (post #2). I just did this yesterday and cleaned the whole valve thoroughly and the ticking went away momentarily but came back but not as loud as it used to.
Old Jan 16, 2004 | 11:59 AM
jayanth's Avatar
2daMax,
you are exactly right this is the thing!I'll do it tommorow.Thanks a lot that was fast too.I recently cleaned my TB and PCV don't know if that has anything to do with this think ticking like crazy.
thanks a lot,
jay
Old Jan 16, 2004 | 12:33 PM
DAVE Sz's Avatar
Hooooooonda.....
After you do that the problem will still probably be there. I did this maybe a month ago and the car did seem to be better all around. However there was still this ticking/grinding sound and it was the TPS, black thing on the TB, so you might want to test this also.
Old Jan 16, 2004 | 01:40 PM
bosa1's Avatar
Thanks, I have the same ticking and hopefully this will take care of this issue.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
