need help
Old Jan 16, 2004 | 09:26 PM
azmaxipad's Avatar
need help
I cleaned my TB today and now the idle won't go below 1000 rpm. I need help. but the car runs great and doens't sound like it's idleing high at all. need help. and ideas PM ME
Old Jan 16, 2004 | 09:28 PM
PoePoe2797's Avatar
Let your car warm up a little, take it for a a 10-20 minute drive and at every complete stop (over 3 seconds), check how low it idles......since its cold, usually it idles a little higher than normal until it completely warms up
EDIT: nm about the cold, you live in AZ ....here in CT its like -10
Old Jan 16, 2004 | 09:38 PM
dss42's Avatar
same here that is what heppens after you clean the TB do the rpms stay at 1k then when you come to a stop they drop alittle then rise back up? there is a small **** next to the TB to adjust it my mechanic did it for me and dropped my rpms to 750 I did not see what he touched I was standing far away but he did it.
Old Jan 16, 2004 | 09:41 PM
PoePoe2797's Avatar
That **** is on the IACV valve and is very sensitive so if you dont know what to do, dont touch it. If you havent touched the IACV valve at all, I doubt you'd need to adjust it. I've cleaned my TB plenty of times and this somewhat happens to me...just drive around a little and it'll go to normal
Old Jan 16, 2004 | 09:46 PM
azmaxipad's Avatar
I drove around it drops down to about 750 then goes back to 1000 and hovers around there. it's a 5spd if that makes a difference. I have a mechanic stayin with my family might have to have him take a look at it tomorrow. I want to be runnin' proper for imports v. domestics and break low 15's .. I hope that helps
Old Jan 16, 2004 | 09:50 PM
PoePoe2797's Avatar
If you drove around and its still doing it, then I say do the IACV screw adjustment. Read the manual carefully and turn the screw in very small increments
Old Jan 16, 2004 | 09:54 PM
azmaxipad's Avatar
sweet I'll try that tomorrow... I'll check the aftermarket manual I have... any other suggestions..
Old Jan 16, 2004 | 09:55 PM
dss42's Avatar
Yea mine still did not fix still jumps up and down at every stop light could it be a sensor that is old?
Old Jan 16, 2004 | 10:04 PM
azmaxipad's Avatar
ya the tach jumps when I drive and it accelerates unevenly. any suggestions on that
Old Jan 16, 2004 | 10:06 PM
PoePoe2797's Avatar
Hmm...I was under the impression that everything was fine and the idle was just high. Now its starting to sound like a problem with the throttle position sensor
Old Jan 16, 2004 | 10:07 PM
azmaxipad's Avatar
put when I accelerate and the tach jumps there is no power surge or anyhting.... wtf
Old Jan 16, 2004 | 10:10 PM
dss42's Avatar
A few people told me it is the throttle position sensor but why would it just brake after cleaning the TB and this heppens to everyone who does that?? how much is it anyways and how much is labor?
