97 Infinti I30 Rear Break HELP !!!! Plz
Old Jan 17, 2004 | 08:11 PM
Noeladams's Avatar
Okay i upgraded the front brakes on the car with no problem, it needed rotors. I removed the rear brakes but cannot get the piston to compress back into the calibur (cant spell i know) I tried to use a c-clamp but that didnt work. I was also told to turn it clockwise and it will go back in. How many times do I have to turn this thing? I have been on it for about 10 minutes and still nothing.
I know there is a tool that will turn it for you but havent got it yet, I have been using channel locks and turning it.
I dont know if this has already been posted b/c I do have the rights to use the search.
Old Jan 18, 2004 | 10:27 AM
droc
First spray some rust penetrant on it near the rubber boot so when it turns it dosent bind up now to turn the caliper in use a pair of needle nose and apply pressure inward as you turn it in if thats not working go to sears and buy the correct tool
Old Jan 19, 2004 | 09:40 AM
Yanick's Avatar
The easiest way to do this, i get a C clamp, tighten it to the piston, than take pliers and twist the piston. You will see it go in really quick. Keep tightening the C clamp and you will be fine.
Old Jan 22, 2004 | 02:46 PM
raybone97-I30t's Avatar
Get the 5$ tool from auto parts store[COLOR=Black]
matts95max
Apr 23, 2025 10:44 AM
ef9
Sep 5, 2015 11:18 PM
