my car (95 maxima se 5spd vs. 2002 spec v 6spd)?!?!?
what would win? I have a y pipe, resonated b pipe, high flow cat, and technosquare ecu, and a frankencar intake vs. a 2002 spec v with headers, intake, high flow cat, cat-back, balance shaft removal, and UDP...
what tire pressures are best for straight line on our cars? i know on the spec v's, its like 28 up front and 38 out back or somethin....I have 234/45/ZR17's all around??!?! what psi for best straight line times? and what rpm should i launch at? dump is better than slipping on our cars right?
Originally Posted by Big D
The SPEC V weighs about 2600lbs and has about the same power.
I wouldn't be too abmitious with my own 95 SE despite the mods you've mentioned. Newer cars, of course, are more advanced in technology than older cars. Unless you are spraying. IMHO, I wouldn't put my 95 in that kind of abuse, its like trying to win a race with an old horse.....its a long shot!
thats horse ****.
so what if newer cars are more advanced? there is only so much a good motor can and can't do. our vq's are extremely solid and much more torquey than those spec v motors, its not abusing ur '95 if you maintain it properly, and know how to drive it fast
no disprespect intended with this post, its my opinion as well, obviously.
Gotcha!!! Answer this: Two well maintained cars. One is always driven hard, always in races. The other driven normally, occassional high speed driving on highways. Guess which one would have more problems?
I just saw a pic of an org member's boosted maxima, the intake manifold cracked in one of the runners from racing! Racing is fun and also a phase that kids go thru unless you race professionally with real race cars. I've had my racing phase too, believe me. But honestly, I wouldn't waste my Maxima on races.
Originally Posted by nismos14
thats horse ****.
Originally Posted by IwANnAMaX96
I don't wanna be a d!ck man but get your stuff straight. What you just mentioned came from a nitrous mishap, not from just "racing." Your statements are too general. The VQ is one of the stoutest, most reliable engines ever built pound for pound. It can defenitely take some abuse. If you wanna be conservative in your driving that's up to you.
When else are you going to spray unless you are racing against someone or at the track against time. It's all racing! Anyhow, It's a matter of personal preferences and I chose to be the conservative one. I'm sure there are more who are too. And then those who want to foolishly race everyone else, more power to ya! And btw, being a d1ck is totally uncalled for, we are all giving opinions in here right so why get bent out of shape?
BTW, I know this is a change in subject, but how long have you had the knock sensor relocation? Any CEL light yet? How's your car running with it so far? I use 91 octane fuel all the time, I think you use higher octane. Would relocating the knock sensor on mine pose any problems?
im conservative too
guys...why does everyone on the boards here dis spec v's if they are so god damn fast? personally I don't think a spec v with the above mods could run the quarter in 14.5 or 14.4...their mods don't net as much i think like ours....like intake for example gets them almost nothing....in either case, I think that it would be a drivers race, but try to keep up in high end with a V6?? i think the spec will run out of breathing at high end! in either case, what if i got those other mods on there? like flywheel, pulley, and intake manifold spacers? would that win in addition to all my other mods? i think with full bolt-ons a maxima would run a 14 flat with a good driver!
no ill effects. it seems to drive just as it should. no cel, but FYI the knock sensor does not trip the cel. i've checked my ecu for codes a few times since having it done, and no ghost code, 0505 everytime. i use 94 octane usually at sunoco, if i can't get that i try for 93 anywhere else. you could most likely get away with relocating ur knock sensor running on 91 and not have any problems but if you hear any knock or pinging, i'd suggest running 93+.
Thanks, I'll try that when the knock sensor code (by itself) comes up and I can not get to the knock sensor. I've done it years ago when I had my first 95 SE, emerald black in color. I remembered that it was a major pain to remove it, I got major cuts in my hand.
yup mine was being way to much of a pain in my butt to get out so i said screw it and its worked fine
I have taken out a Spec V on the highway and from a stop. They are no competition for us unless they have forced inductiion or nitrous installed.
Lakersallday24
Jun 16, 2019 01:35 AM
fastcarny
Aug 12, 2015 03:50 PM
Team STILLEN
Aug 10, 2015 04:29 PM
yat70458
Aug 3, 2015 01:16 PM
