gas smell!!
Check your fuel lines underneath the hood. Might be the rubber fuel lines going to the fuel filter located in the middle on the firewall right infront of the windshield. Give that a try first. If not then see if you have any fuel leaking underneath the car after parking overnite. This will at least pinpoint where you might have a fuel leak. Good luck and let us know how things turned out.
Ken
Ken
Originally Posted by mondonitro
help my 95 max smells like gas inside the cabin at startup?what could cause this??? any help thanks
Someone in another thread said that the o-rings might need to be changed or that a fuel injector is dying. I have the fuel smell too and I'm going to replace the o-rings for the front injectors when the weather gets better.
I think my fuel injectors are sticking since the car runs better with fuel injector stuff in the tank
Gas smell on cold mornings first start of the day is often due to fuel injector o rings shrinking in the cold and letting fumes/gas out. Other causes could be fuel line leak, fuel filter leak or fuel tank leak. Also the evaporative containers with charcoal in them could be old or broken, which can cause a fuel odor.
ef9
Oct 4, 2015 08:43 AM
