Loud squeeling just after I start the car?
Not always, but a couple times over the last few days when I started my car there was that loud squeeling for a few seconds, and then it went away. I've heard it on other cars before. Does this just mean that I need a new belt?
squeeeeeeeeele
I had the same problem a few months ago. It turned out to be the power steering belt. Check the tension pulley and the belt an you will find your problem. DO NOT take it to a stealership to have it done, they will rape you. Have it done by your local shop or do it yourself.
I have the same problem but it's not a squeel, it's a loud noise that i can't explain but this only happens when it's really cold outside and starting the car after 24 hours or so. Do you have the same symptoms?
I have similar problems. Whenever the car sits over night and it's cold, I get a loud squeel followed by a bad rattle (like something is lose, maybe the timing chain) on start-ups. I can never figure what that rattle is. I know that the squeel was caused when I clean my engine with the engine degreaser. The chemicals in the degreaser degraded my belt. I will change them out as soon as I get my Unortho. UDP. Anyhow, any of you hear a loud rattle during cold start-ups?
yeah would this have to do anything with my tak revin up when i turn the wheel in either direction/?
cause i have the same prob but its not really that loud just KINDA loud, u know the kinda noise only YOU can hear lol
I replaced it myself and shes purring like a tiger now when I start her up.
You can try regreasing it also. Go here for directions: www.motorvate.ca
In case you haven't noticed, there's a nice thread starting about how to change these belts.
http://forums.maxima.org/showthread.php?t=276984
when i bought my max i had a problem with a weird sound when the climate control was off took it to my shop and it ended up being something bad with the a/c and it would make a noise unless it had a load on it like when the a/c was on. hope this helps someone
kjlouis
Nov 24, 2018 06:09 AM
kirkhilles
Aug 8, 2015 10:53 AM
