would this ECU swap work with no problems?
Old Jan 21, 2004 | 06:30 PM
kingrukus's Avatar
no more maxima...
Hi All,
I am thinking about swapping a 98 5-speed SE ECU into my 98 5-speed GXE. The reason I want to do this is to eliminate the speed limiter. Is this a straight foward swap, or are there any precautions I should take? Will this even work in helping me acheive what I want to do?
I am trying to avoid splicing my harness to get rid of the limiter, as per mzmtg's instructions, mainly because I would like to retain the speedo readings when going past the limiter.
Old Jan 22, 2004 | 03:02 AM
Nismo's Avatar
direct swap no problem
Old Jan 22, 2004 | 04:40 AM
Tyrexx's Avatar
How much do those run? Is it really worth it? You might just want to get a Jim Wolf Technlogies ECU if you plan on ever getting VI.
Old Jan 22, 2004 | 12:01 PM
Nealoc187's Avatar
SLOW
It will work without a problem, however you are misinformed as to the fact that you will lose your speedometer when when you break the connection (like if you put a switch on the wire that mzmtg describes). Your speedometer will still work just fine. I've had mine on a switch for years.
Old Jan 22, 2004 | 09:15 PM
kingrukus's Avatar
no more maxima...
I believe they are fairly cheap used from wreckers.
Old Jan 22, 2004 | 09:20 PM
kingrukus's Avatar
no more maxima...
Thanks for the info guys.
...however you are misinformed as to the fact that you will lose your speedometer when when you break the connection (like if you put a switch on the wire that mzmtg describes). Your speedometer will still work just fine. I've had mine on a switch for years.
Really? Hmm...this really makes me re-think my plan. Does anyone have the sprintmax writeup with the pics? I cannot seem to find it!
Old Jan 22, 2004 | 09:49 PM
maxima98vspec's Avatar
Originally Posted by kingrukus
Hi All,
great idea i might do that also.
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
kenc15
Aug 5, 2015 08:29 AM
