CEL codes please translate
Old Jan 24, 2004 | 07:19 PM
DaThrillr's Avatar
i got the codes P0500, and P0600 can some one translate these to reg codes so i can diagnose and research them thanx in advance..
Old Jan 24, 2004 | 07:34 PM
Jatan's Avatar
P0500 = 0104
P0600 = 0504
Old Jan 24, 2004 | 07:41 PM
minsbang's Avatar
goto autozone and they'll tell you Exactly what you need to replace or repair..... they will check your CEL For FREE.
i went to one in Brooklyn, NY
Old Jan 25, 2004 | 05:23 AM
Kevlo911's Avatar
Kevlo for President
0104
Diagnostic Trouble Code 0104 points to a problem with the Vehicle Speed Sensor or the associated wiring.
The Vehicle Speed Sensor installed on the transaxle. The part inside the transaxle has a plastic gear which is driven by the internal parts of the transaxle. The part outside is a signal generator which produces a square wave of amplitude 5.2 volts and frequency proportional to vehicle speed.
Remove the VSS, attach a voltmeter to the electric leads, and spin the gear
by hand. If you get zero volts, it's dead.
One owner discovered his VSS was not fully seated in the transaxle. He just tapped it inward, and retightened the 10mm mounting bolt.
For more information please refer to the Chilton repair manual (page 4-22) or the Haynes repair manual (page 6-16).
0504
Diagnostic Trouble Code 0504 points to a problem with the Automatic Transmission Communications line. Pulse signals are exchanged between the Engine Control Module and the Transmission Control Module to assure smooth shifting during hard acceleration or deceleration.
This malfunction is detected when the ECM continuously receives an incorrect voltage from the TCM. Possible causes include...
- Harness or connectors (The communications line circuit between the ECM and the TCM is open or shorted.)
- TCM
- Discharged or faulty battery
Old Jan 25, 2004 | 10:45 AM
DaThrillr's Avatar
do u guys think this is because of my VB mod?
i dont know what could have brought this on....
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
