Bumper Removal Process
Old Jan 25, 2004 | 07:13 AM
Conrad283's Avatar
I need a truck
To those that have done the ol' removal of the front bumper. I'm told it's a fairly easy process.
First, I'd have to take off the plastic/metal in the whels well. Then there are a couple of screws/nuts/bolts (whatever). I'd have to repeat that for both sides.
Second, there are like 6 screws on the underside of the bumper.
Is that it?
I know how to take the grill, headlights and corner lights off, so that's not a problem for me.
Thanks,
Andrew
97-99 Conversion here I come
Old Jan 25, 2004 | 12:46 PM
vsamoylov
ok, here is the process.
remove the bolts on the bottom of the bumper (6 of them),
remove corner lights (the ones that are next to the headlight) remove headlight and grill and on the top of the bumper, there are a bunch of bolts that go from one side to the other
remove clear corners
and the way I removed the 3 bolts that hold the side of the bumper is
unscrew bolts and screws on the plastic things that goes under the fender but only remove the front ones
then bend bakc the front of the plastic piece and stick your hand into the fender and you could see 3 nuts there
on the passengers side though, remove the coolant resoivor cause you can't reach the nut from the bottom
that is it you get it?
now why are you doing the 97-99 conversion?
Old Jan 25, 2004 | 12:50 PM
Conrad283's Avatar
I need a truck
I do not like the 95-96 Front or the Stillen kit either. So therefore I'll get the best of both worlds with the 97-99 everything
Old Jan 25, 2004 | 12:55 PM
vsamoylov
fogs for sale then?
Old Jan 25, 2004 | 01:02 PM
Conrad283's Avatar
I need a truck
They will be
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
Noela
Sep 26, 2015 08:22 AM
ricky7780
Sep 24, 2015 06:50 PM
