Will It Bolt On !
Old Jan 25, 2004 | 04:00 PM
krismax's Avatar
Father of the 00 VI
Will It Bolt On !
i'm frustrated i can not find this anywhere .Will the 5 gen variable intake bolt on the 4th gen, (96) with no interference (injectors fuel rails). If it does interfere can i bolt the 2000 lower intake with 2000 injactors and rails and expect it to connect to the 96 connectors for their injectors. If the 2000 VI will bolt right on please tell me because ,i will order the stuff next week. Because all the other stuff will be cake or unnessary.i.e fast idle control solenoids for AC and PS.
Heres the things that need to be switched from 96 manifold to 2000.
1. power brake booster hose ( probably a spot for it already on there)
2. IACV ( i will machine a bracket that it will fit into and bolt on 2000 manifold)
3. I think there is a crankcase breather hose on the front left of the IM (another thing that will probably hook up on the 2000 manifold)
4. Throttle body this is the easiest part ,i can connect any TB to any car.
5. The 2000 probably has a small egr tube i will cut the head off that and weld it to the 96 tube .(half and half of each)
If you have things to add ,please do. I just began to reseach this. Help would be very appreciated.
If you come in here to be negative please find another thread.
Old Jan 25, 2004 | 07:52 PM
nismos14's Avatar
§è~® f®ÈÄk
for one thing the hood will not clear. thats all i can add for now
Old Jan 25, 2004 | 08:17 PM
krismax's Avatar
Father of the 00 VI
Thanks for the info ,yes iv'e heard that but iam sure if the webbing was cut in that area it would clear. If i have to i'll put a hole in the hood.
Old Jan 25, 2004 | 08:20 PM
SXN's Avatar
SXN
it would need a pretty big lift up to fit....more just just the webbing.
Old Jan 26, 2004 | 07:18 AM
willis's Avatar
My heroine
Not to be negative, but I am seriously wondering why you are considering this route as opposed to getting a mevi. There is currently a gd for one (or was recently) and a few for sale on the 4th gen for sale forums.
Just tossing out an easier option.
Old Jan 26, 2004 | 07:24 AM
plurco's Avatar
Man I could fab you a custom fiberglass hood to work around it. I could even make it look trick as hell :-)
Old Jan 26, 2004 | 11:09 AM
nismology's Avatar
I'm pretty sure he knows about the MEVI. If you have to ask this question, perhaps you should read up on how both the 4th and 5th-gen VI's work and how they affect the powerband.IMO, the MEVI is a half-arsed VI and the 5th gen VI would produce more power at all RPM ranges.
Old Jan 26, 2004 | 12:15 PM
SXN's Avatar
SXN
the mevi is a pretty cheap and easy VI system. but its available, and it is a direct fit. so far, you cant beat it.
Old Jan 26, 2004 | 01:28 PM
krismax's Avatar
Father of the 00 VI
Thanks maybe i'll take you up on that after its done.
Like iv'e been saying ,everything people put as problems in doing this are all very easily solved . But i need info on the lower intake manifold. Has anybody actually bolted this to their 4th gen? My ? is do i need the 2000 lower manifold with injectors and the such.
Old Jan 26, 2004 | 02:51 PM
willis's Avatar
My heroine
perhaps I should .. I assumed he knew about the mevi was more looking for a quick explanation as to why it's not acceptable..
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
