Stuck on what performance mods to do
Old Jan 26, 2004 | 07:39 PM
MaxGR97's Avatar
I ALREADY have a y pipe and an intake. I WILL BE getting a full catback. I will then have around $950 to spend on other performance mods, and i have no clue what ones are the best to do for the money. I want to keep my car N/A so no NOS or S/C. Just tell me what you would do, thanks.
Old Jan 26, 2004 | 07:41 PM
my99maxisnice's Avatar
Interested in suspension? you redo all of it for under that price.
Old Jan 26, 2004 | 07:44 PM
MaxGR97's Avatar
I dont know, i was looking into lowering, but ~$500 for 1.5 inches is alot, but no, this $ is just for performance
Old Jan 26, 2004 | 07:45 PM
maxima98vspec's Avatar
if u don't know what to do with ur money just let me have it, il use it wisely jk, i would go for a flywheel or a UDP, or maybe got with some light weight rims like 16's or 17's rotas from ebay, they are about 15 lbs compared to 40 lbs stock on a GXE im not sure what its for SE or GLE, it will help alot. There is also the carbon fiber hood, and a couple of other things. but not that many mods which sux. Im still waiting for nismo to come out with mods for the max, when is that going to happen?
Old Jan 26, 2004 | 07:47 PM
Deagle's Avatar
wants the ads to die
Mevi and ecu. I was thinking about doing that until I came to my senses and realized my max was too far down the road in mileage to be putting that much money into, but before I realized that, the mevi/ecu seemed like the way to go. If not both, at least a ecu.
Old Jan 26, 2004 | 07:51 PM
I don't think a 97 could get an ECU w/o problems.
Old Jan 26, 2004 | 07:55 PM
Deagle's Avatar
I thought there would just be a CEL?
Old Jan 26, 2004 | 08:00 PM
MaxGR97's Avatar
Ya, some of my options i was thinking of were MEVI, JWT ECU, or Underdrive Pulley, but i dont know what one would help the most alone? prolly ECU? but something about 97s with the JWT something is wrong with it i dont know...But I just dont know which one would give the most power and so on.
Old Jan 26, 2004 | 10:24 PM
formz
Here's a thought... put the money in the bank for a rainy day when something really cool comes your way.
Old Jan 26, 2004 | 10:29 PM
Phatmax98's Avatar
You could get an MEVI, ECU, Test Pipe or High Flow Cat, better spark plugs, and that's about it....oh and a UDP..but IMO they don't do a whole lot!
happyricefob's Avatar
V^___^V
$500 will get you spray kit will help you pick up some instant WHP right away.
save the other $450 for drop, or get brake system.
Old Jan 26, 2004 | 11:08 PM
aznprid972's Avatar
wait.. u guys lost me on the ecu part... so the 97-99 models cant have an ecu w/o the check engine light showing?? so really the 95-96 actually benifit from this?
Old Jan 27, 2004 | 03:41 PM
MaxGR97's Avatar
Anybody else have any suggestions?
Old Jan 27, 2004 | 04:10 PM
Brudaddy's Avatar
I don't know about the GXE's, but I have a 1999.5 SE, and the wheels weigh something like 19.6lbs. Lighter wheels are a good idea though. They will considerably help your performance if the wheels actually weigh that much. I don't know about 40 lbs though. That is a lot. That is like 20" chromies or something.
Old Jan 27, 2004 | 04:34 PM
that's just what i've heard, im gonna have to weigh them when i take them off next time and il let u know. there was a couple of people saying they were like 42 lbs so i dono.
Old Jan 27, 2004 | 04:44 PM
Deagle's Avatar
That's also what I've heard, with the wheel weights going from greatest to least (SE, GLE, GXE)
Old Jan 27, 2004 | 04:46 PM
i think the SE are the lightest, am i right? they go from SE GXE GLE, SE being the lightest. riiiiiiiiiiiiiiiiight?
Old Jan 27, 2004 | 04:57 PM
Ant96GLE's Avatar
40 pounds sounds like the weight of the tire and wheel. I find it very unlikely that a stock sawblade or steelie weighs 40 pounds by itself.
Old Jan 27, 2004 | 05:39 PM
Torgus's Avatar
buy a suspention...hell save up a bit and get JICs!
Old Jan 27, 2004 | 05:43 PM
Max Noob's Avatar
whats a car that can go fast if it turns like a boat?
go suspension..
350 agx
100-200 springs of your choice
100-150 rear sway bar
25-35 ebay front strut bar
yea that's what i think also but im not 4 sure.
Old Jan 27, 2004 | 06:30 PM
MaxGR97's Avatar
SUSPENSION IS NOT PERFORMANCE I might get suspension, but im talking aobut what performance as in under the hood. Im getting 18's but are prolly not too much lighter. So if you have any PERFORMANCE mods you would suggest, please tell.
Old Jan 27, 2004 | 06:39 PM
Taken2DaMax's Avatar
just get a JWT ECU. You may have a CEL but it's nothing more than a wiring 02 sensor error. It won't take away from your performance. It's harmless. Plus you will be kicked back into your seat with this mod.
I'm a 97se hoping on getting this ECU back from JWT in a couple of days.
Old Jan 27, 2004 | 07:06 PM
Max Noob's Avatar
ecu + mevi.. u should be broke after that. upd if u still got 150 laying around.
Old Jan 27, 2004 | 07:10 PM
Conrad283's Avatar
I need a truck
Get some big Stickers .. Lots of HP .. Suspension not performance .. Pffff .. What about braking? Faster you go the more braking power is needed. Or is braking not defined under "performance" either?
Old Jan 27, 2004 | 07:18 PM
AsthmaMax11's Avatar
Has anyone mentioned CAMS??? but they are going to be alot to install...
Old Jan 27, 2004 | 07:22 PM
Torgus's Avatar
being able to go real fast and not be able to handle it is
spend your cash on a good suspension. or get a mevi and chip like above mentioned its all thats left in that price range..other then a udp...
oh you said you were getting 18's? hello 4x4. buy some coilovers(JICs), RSTB, RSB(?),FSTB.
good luck with whatever you get.
Old Jan 27, 2004 | 08:14 PM
kingrukus's Avatar
no more maxima...
You are way off. Stock GXE/GLE sawblades wheels are lighter than most rota 17" wheels. They are about 15-16lbs a piece.
Anyhow, If I were you I would definitely focus on suspension. Stock 4th gen handling is horrible.
Old Jan 27, 2004 | 08:19 PM
mitch33x's Avatar
Thats what I'm doing
Old Jan 27, 2004 | 11:57 PM
Midknight MAXX's Avatar
INFO on MEVI/JWT ecu
Quote:
Originally posted by SteVTEC
USIM Average Power 2000rpm - Redline: 121.9 fwhp
MEVI Average Power 2000rpm - Redline: 122.6 fwhp
Overall you do not gain ANY power overall under the entire RPM curve. The MEVI merely takes away power from the low/mid-range and adds it all back to the top-end, because the total power under the curve is nearly indentical between the two manifolds. This could explain why some are having trouble getting better 1/4 mile times with the MEVI.
USIM Average Power 4500rpm - Redline: 148.2 fwhp
MEVI Average Power 4500rpm - Redline: 156.2 fwhp
In the peak power band is where the MEVI really shines, and it adds an average of 8 fwhp overall vs the USIM. So if highway power is what you want, the MEVI gives you much better high speed pulling power than the USIM does. But around town, a USIM VQ would most likely pull on an MEVI VQ.
Quote:
Originally posted by Nealoc187
After a few minutes of plugging and chugging I came up with the following figures for average HP over the typical drag racing range:
USIM: 166.60 average HP over 4000-5800RPM
MEVI: 167.26 average HP over 4350-6300RPM
Advantage MEVI by 0.66 HP (Why'd I spend $650 on this again? Read on...)
Nealoc goes on to say that the MEVI has a slight advantage at the track because you are accelerating in a higher RPM range and avoid the 3-4 shift. He also says that after the 1/4 mile the MEVI Max would seriously pull on the USIM Max. Again I like my car to have streetable power and acceleration after 100 MPH would not be any use to me.
This is all quoted from reputable sources here on the ORG. THe $650.00 plus installation may not be worth it. I don't know if you've seen this SITE but there is'nt a whole lot of options short of forced induction (which you stated you don't want) via S/C, turbo, or NO2. That could be why there's a lot of suspension talk. Short of a Under Drive Pulley there just is'nt much else.
Old Jan 28, 2004 | 01:56 AM
MaxiSpeed97's Avatar
Are you manual or auto?
If you're manual, upgrade clutch/flywheel
If you're auto, try to get the VB mod
Get the pulley either way, it's worth it IMO
Old Jan 28, 2004 | 08:19 AM
MaxGR97's Avatar
I will be getting suspension later, and probably new brakes too, but im just syaing performance as in under the hood. Sorry if i was mean or something, but ya i will be getting those mods later too. thanks for your help people
Old Jan 28, 2004 | 08:48 AM
ohannon7's Avatar
Plus one on the Mevi stuff that midknight maxx was talkin about. I dont doubt the power that it makes but I would rather have the low end power than top. Im not intereasted in how hard it pulls goin down the highway, Id rather have crazy power from a stop or slight roll......
If I had that much $ and same mods I would get UDP and NOS. Since your looking for NA power maybe Cams or port and polish.....
Old Jan 28, 2004 | 08:53 AM
mforrest100's Avatar
Though it isn't performance what is the sense of grabbing all the extra HP if you cannot handle the car properly. Suspension helps out a lot on our cars. It actually makes you feel like the car drives faster because it handles so much better. I had suspension before I had any performance on my car and I loved it. Made me drive faster.
Old Jan 28, 2004 | 09:09 AM
ohannon7's Avatar
I dont feel safe going fast around corners and what not w/ out being lowered a little bit, I wasn't expecting much if anything from my FSTB, It has been the best $20 I've spent on my car....
You gotta think, when you play GrandTurismo or whatever-what are the first things you upgrade....
Old Jan 28, 2004 | 09:21 AM
Brudaddy's Avatar
You wouldn't happen to live near Eglin AFB, would you, MidKnight MaXX?
Old Jan 28, 2004 | 09:26 AM
ohannon7's Avatar
You wouldn't happen to live near Eglin AFB, would you?[/QUOTE]
Why? You live near Keesler AFB huh?? Im at Lackland.....
Old Jan 28, 2004 | 09:31 AM
Brudaddy's Avatar
Why? You live near Keesler AFB huh?? Im at Lackland.....[/QUOTE]
Nope. I don't. Keesler is way down on the coast. 3 hrs away. I was just seeing how close he lived there (being friendly), because I have a friend that is stationed there and have gone to see her a few times. That's all.
What you do at Lackland?
Old Jan 29, 2004 | 09:56 AM
Yeah I do. I work on Hurlburt Field.
Old Jan 29, 2004 | 10:02 AM
ohannon7's Avatar
computer stuff......
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
