Changing colors of LEDs in car...how do I do all of this?
Old Jan 27, 2004 | 02:05 PM
WillMax95's Avatar
I want to change the color of all of the LEDs in my car to blue, how would I go about doing this? Do I have to change the bulb itself, if so, where can I buy new blue bulbs?
Old Jan 27, 2004 | 03:00 PM
ManualMaxima's Avatar
5th Gen till she dies!
look at the How-to sticky!!!
Old Jan 27, 2004 | 05:39 PM
MadChef's Avatar
In short:
Whenever you are replacing an existing LED, just remove the old one, and solder in a new LED.
Whenever you are replacing a light bulb, replace with an LED and a resistor.
New LEDs can be bought from ebay, or from sites like www.superbrightleds.com
The 4th-Gen HowTo's will give you someplace to start.
Old Jan 27, 2004 | 05:51 PM
Nismo's Avatar
I cant seem to get my LED turn signals working wven with the resistor. IT says to wire the resistor 1 wire to ground the other wire to the postitive. wouldnt I supposed to wire the resistor in line on the positive?
Old Jan 27, 2004 | 07:25 PM
MadChef's Avatar
Originally Posted by Nismo
I cant seem to get my LED turn signals working even with the resistor. IT says to wire the resistor 1 wire to ground the other wire to the postitive. wouldnt I supposed to wire the resistor in line on the positive?
Yikes.
The resistor should go in-line either on the positive side or the negative side (doesn't matter).
Old Jan 27, 2004 | 07:57 PM
WillMax95's Avatar
thanx guys
Old Jan 27, 2004 | 11:09 PM
Nismo's Avatar
Originally Posted by MadChef
Yikes.
here the instructions for resistors on the superbrightled.com site
CONNECTION INSTRUCTIONS: Using includes splice taps, connect one wire to ground and the other wire to the turn/brake wire. You do not have to cut your car's wires. Squeeze splice taps with pliers. One Load Resistor required for each turn signal bulb. No instructions are include with these kits.
minsbang
Sep 11, 2015 08:48 PM
MplsMadMan
Sep 11, 2015 07:54 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
mpbclutch33
Sep 8, 2015 06:21 PM
