O2 Sensor replacement
Old Jan 28, 2004 | 08:36 AM
sbennell's Avatar
About a month ago, I got a CEL to change the O2 sensors. I haven't noticed a performance or fuel efficiency drop. Should I change the proper sensors right away or can I let it go for a bit. Also, are their any issues with using a cheaper NGK sensor as opposed to the more expensive OEM part?
Old Jan 28, 2004 | 10:12 AM
twiggy144's Avatar
You can wait if the CEL lamp does not bother you, or if ou dont see a change in performance. Mind you the rear sensor does not feed into the ECM in a closed loop feedback for engine management. The rear sensor will never affect performance.
Get the least expensive O2:
buyoxygensensors.com
Old Jan 28, 2004 | 10:15 AM
twiggy144's Avatar
as a side note, did you pull the codes to determine the CEL lamp had to do with O2 sensors?
Personnally the cel lamp annoys me to the point I would have not waited a month.
Old Jan 28, 2004 | 10:23 AM
95Max's Avatar
Change it now...malfunctioning O2 can destroy your cat
Old Jan 28, 2004 | 03:27 PM
sbennell's Avatar
Thanks for the advise. I'm going to replace them with Bosch sensors.
mrc00l88
Jan 25, 2024 01:14 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
