0902 code
Old Jan 28, 2004 | 12:55 PM
Ted_MEng's Avatar
0902 code
What is 0902 code? I found that for A32 platform in Japan and Europe that means problem with rear O2 sensor heater.
What about NA models?
Old Jan 28, 2004 | 01:40 PM
Kevlo911's Avatar
Kevlo for President
Are you sure you read the code correctly? Check it again. http://forums.maxima.org/showthread.php?t=104931
Use that.
Old Jan 28, 2004 | 07:05 PM
Ted_MEng's Avatar
Absolutely
Yeah, I've checked 3 times. And it comes on in about an hour after ECU reset.
Old Jan 28, 2004 | 08:05 PM
twiggy144's Avatar
0902: downstream oxygen sensor heater or circuit fault ( ref: Haynes )
Kevlo : would you add this one up?
The rear O2 sensor has no effect on PCM control of the air/fuel ratio mix.
My suggestion for fixing: fool the ECU with a simple automotive low wattage lamp bulb. Locate the oxygen sensors 2 heater wires (these 2 are identical in color) and install a no 194 (for example) 12V light bulb on them. The rear sensor connector is under the driver seat: easy to work on. Splice these 2 wires and install the bulb somewhere under the seat.
A new code for the rear sensor might pop up after the 0902 clears away, in which case I guess you will want to replace the sensor or get a sensor simulator (that is what I installed)to turn off the CEL. This lamp bulb is inexpensive, it is worth a try.
Old Jan 29, 2004 | 02:04 PM
Kevlo911's Avatar
Kevlo for President
I can't edit after 24 hours
Old Jan 29, 2004 | 02:32 PM
twiggy144's Avatar
No I meant add it to ECU codes doc .files (I tought you were the owner of that file , sorry)
Old Jan 31, 2004 | 06:39 AM
Kevlo911's Avatar
Kevlo for President
Well, this week or next week I am going to make a hread that converts all the PXXXX codes to DTM style according to the Haynes manual. So it will have that code and more. I will add the link to the ECU codes doc file as soon as I finish.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
