99 Max with knock sensor and other problem Help!
Old Jan 31, 2004 | 12:17 PM
mcnrg6980's Avatar
my 99 max has a check engine light on with
P0325 Knock Sensor
and 1130 Swirl Control Selenoid (california)
the car is no longer in california.
I was wondering can i just take off the selenoid and if not how much would it cost to fix these things and can i do it my self.
Any and all info would be great i would use the search function but its disabled
Old Jan 31, 2004 | 12:44 PM
njmaxseltd's Avatar
You can't take the swirl control out unless you change the intake manifold and the ECU. Replace the selenoid and clear the error. The knock sensor code should go away. Check in a few days to see if you have the KS code. If you do replace that too. The KS code may be set if the swirl valves stay closed because of the bad selenoid. That will definately make the car run poorly.
Old Feb 1, 2004 | 10:49 AM
RichMax's Avatar
Boosted like Snipes tax refund
Easier said than done on the knock sensor. He has a 99 california emissions Max with the swirl control valve. The Swirl control valve actually blocks any access to the knock sensor. We had this discussion a long time ago, but the only way to get at the knock sensor under these conditions is to remove the intake manifold.
My ks isn't getting replaced until I get my MEVI installed. In the meantime, a resistor can be bridged across the KS to simulate a working ks attached to an engine which isn't knocking (your engine should be knock-free unless you are running less than 91 octane fuel and/or have other engine problems).
Old Feb 2, 2004 | 02:53 PM
mcnrg6980's Avatar
And how would i do this can someone give me a tutorial or some other info i would rather do this myself also where can i get these parts cheap
Old Feb 3, 2004 | 09:37 AM
RichMax's Avatar
If i recall correctly, in a 99.5 max there is a single connector harness for the ks that you can actually reach. (You're looking near your dipstick...) (The ks is unreacheable for any practical purpose ina 99.5 cali-spec Maxima, so don't try unless you are going to remove the entire upper intake manifold.)
that electrical connector has two terminals, and it directly connects to your ks via a male connector a little further down. After detaching the female connector (the one closest to you) from the ks, place a 550kOhm connector accross the terminals (correct me if the resistance is wrong- you want a resistor with the exact same resistance as a ks operating in normal spec.)
Once you do so, and reset your ecu, you'll note a power increase as your engine moves back to optimized timing. Watch very carefully for knocking/pinging (as you are now the only means of detecting them).
Old Feb 3, 2004 | 09:40 AM
mzmtg's Avatar
Minister of Silly Walks
Sorry, that's funny.
Old Feb 3, 2004 | 09:49 AM
RichMax's Avatar
I too, am a noob, and it hurts me so....
But whatever you do, DON'T USE ANYTHING LESS THAN 91 OCTANE FUEL, ESPECIALLY IF YOU COMPLETE THIS MOD!!!!
kjlouis
Nov 24, 2018 06:09 AM
Roymg
Sep 3, 2018 05:10 AM
maxinout93
Oct 27, 2015 01:29 PM
Slamrod
Sep 3, 2015 07:38 PM
maxinout93
Aug 20, 2015 02:17 AM
