Sea Foam anyone??
Old Feb 2, 2004 | 09:01 PM
amax2nv97's Avatar
Sea Foam anyone??
I heard about seafoam awhile back and i was wondering if anyone has used this before? if so i need some instruction or pic's of how to use the stuff seem like a decent thing to do before an oil change...thanx
Old Feb 2, 2004 | 09:02 PM
my99maxisnice's Avatar
I heard that you shouldn't do it yourself if you don't seriously know what you're doing....steered me away. LOL
Old Feb 2, 2004 | 09:08 PM
DAVE Sz's Avatar
Hooooooonda.....
I used it, 3 cans(not at once). First can went into the intake to get the crabon deposits out and fuel. Did it work? Beats the hell out of me. Next 2 bottles went into the gas tank to clean up the injectors. Did it work? Not yet, maybe it needs a month or 2. To put it in the intake manifold use the IACV hose, the big black hose coming out of the intake on the right side. Disconnect it from the intake and pour in SLOWLY while the car is running. To turn off the car just plug the hose with your thumb.
Old Feb 2, 2004 | 09:19 PM
SXN's Avatar
SXN
wouldnt that throw a code? sounds bad anyway
Old Feb 2, 2004 | 09:20 PM
DAVE Sz's Avatar
Hooooooonda.....
You'll get a MAF code because the IACV is disconnected. I don't see a problem though.
Old Feb 2, 2004 | 09:21 PM
SXN's Avatar
SXN
just that the car thinks the IACV is so plugged, it killed the engine
Old Feb 2, 2004 | 09:59 PM
DAVE Sz's Avatar
Hooooooonda.....
The iacv is used to supply air while the car is idling, if there is no air the car shuts off. No air, no fuel, no problem. Only thing that might be bad with this is that the IACV is sucking in unfiltered air.
Old Feb 2, 2004 | 10:09 PM
Taken2DaMax's Avatar
true the car will still run but it's not healthy for the car to do this. The car will throw a code but you can just reset the Ecu after you are done. I pored 1/4 seafoam through the IACV and the rest in the gas tank. Turned off the car for a few minutes. The car had a hard time restarting but with a little gas it will start. Keep the car on and in a few minutes you will smoke out the neighborhood literally.
Old Feb 2, 2004 | 10:12 PM
SXN's Avatar
SXN
thats what i thought
blakkheartt12
Sep 17, 2015 08:11 AM
97_GXE
Sep 15, 2015 06:47 AM
Balkins
Aug 12, 2015 06:39 AM
SB97MAX
Jun 15, 2001 01:13 PM
SeR
Nov 27, 2000 07:47 AM
