E-brake is messed up
Old Feb 4, 2004 | 10:08 AM
shaz's Avatar
I dont know if its because its winter or what (its very cold in CT). It doesnt matter if its 0 or 40 degree's its just since around November my ebrake is totally messed up. If I use it even for a few mins, when I come back and release it, it doesnt fully release all the way. The ebrake is stuck around 2 clicks (if that makes sense). So I drive around with my ebrake on (even thought the handle is all the way down) for a while and I can feel the car pulling a little bit and by the time I've driven for 20 or 30 mins it finally fully releases. I can tell when its stuck or fully released depeding on the play in the handle (when its released all the way the handle has tension right away, when its stuck the ebrake handle will pull up easily 2 or 3 clicks). Does that make sense? Anyone have any ideas? thanks
shaz
Old Feb 4, 2004 | 02:16 PM
twiggy144's Avatar
Same thing happened to me when days were below freezing point. I ended up replacing one of the rear ebrake cables. (right side) Cable cost: $65. I did the work myself.
Old Feb 4, 2004 | 02:43 PM
ericdwong's Avatar
Ah yeah, the 4 gen ebrake sticking! Check the rubber around the cables, they may (probbly are) cracked and lettin water in.
Old Feb 18, 2004 | 10:11 PM
nissanlover's Avatar
I have the same problem I had my E brake Un-frozen for lack of a better word, but it soon froze again, so I think it is that it is frozen, but try to let your car warm up for about 10 minutes it seemed to help me at least most of the time.
Old Feb 19, 2004 | 04:42 AM
twiggy144's Avatar
Depending if its the right, left or center cable, the heat from the exhaust pipes might "unfreeze" the cable, if the ambiant temperature is not too far below freezing point.
litch
123
Jan 4, 2024 07:01 PM
wyobbagy
Jan 3, 2023 12:03 PM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Colossus
Sep 9, 2015 05:46 AM
