spoiler brake lights
Old Feb 11, 2004 | 09:07 AM
johnmadmax's Avatar
Hello people, does anybody know where can I get a spolier brake light to replace mine that is not working? Also the fog light kit to upgrade mine. I'll check
w/ dealer but is kind of pricy....any suggestions
J.
Old Feb 11, 2004 | 09:15 AM
lxl - MaX's Avatar
J.
DO NOT go throught the dealer.
Is the bulb out or is the actual light cracked or what?
Old Feb 11, 2004 | 09:19 AM
johnmadmax's Avatar
The LED light is out
Old Feb 11, 2004 | 09:27 AM
astil's Avatar
I had the same problem...Follow the wire that goes in the spoiler and check the little connector...If I remember right mine was bad, so I took (cut) the connector off ,and connected the wires directly. Make sure that you follow the wire colors, and you don t reverse them. Usually, LED s don t go bad too often, and not all of them in the same time. If they are all bad, the problem is in the wiring somewhere. I think that if you know a bit about wires and electricity, you could fix the light and spare yourself some $$.
Old Feb 11, 2004 | 12:03 PM
BLACKICE99's Avatar
I had to go to a small shop ,not to mention alot of others to find my spoiler led housing,its not an OEM ,so i had to find where sells them and ask if they could get just the light housing. good luck
tsi6001
Oct 3, 2022 10:23 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
