Fan switch
Old Feb 14, 2004 | 05:24 AM
wiseguy6199's Avatar
Fan switch
My car's fan switch, the one that selects the 4 speeds, does not work properly, the position that works is when I select position number 4, which is the highest speed.
This was some time ago, but last week I noticed that this switch does not start the A/C as it used to do !!!!!!! (even on 4)
Old Feb 14, 2004 | 05:39 AM
njmaxseltd's Avatar
You have two seperate issues here.
1) The fan speed - Change the fan resistor. It's located under the dash, passenger side, on the HVAC duct work after the blower motor. There's a plug with a few wires going to it, thats the resistor block. Get a new one from Nissan first so you know what your looking for when your down under there.
2) Your A/C system either lost some R134 or the temp is below 30F. Either of the two will cut the circuit so the compressor clutch woun't engauge.
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
