spark plug pics....normal?????
Old Feb 15, 2004 | 04:30 PM
infinitiblast's Avatar
Ok I took a picture of one of my spark plugs.............but they all looked like this some whiter than others..........is this a lean condition??? or what?
Old Feb 15, 2004 | 05:50 PM
Keith P's Avatar
And too hot? Is there visible distortion on the ceramic? Check for intake manifold leaks after the MAF. Check the coolant temp sender. If too high a resistance, the ECU could think the coolant is coller then it is and be starving the engine.
Old Feb 15, 2004 | 05:52 PM
mansurxk's Avatar
yup, same picture in the haynes manual, hes right, check all that stuff out
Old Feb 16, 2004 | 03:40 AM
Will do . I have had a noticeable hesitation, and lack of power problem for about a month.
Old Feb 16, 2004 | 06:34 AM
astil's Avatar
Looking good. Nice and clean burning engine...The hesitations could be due to other problems. If the fuel that is used is 87 , that may be the answer to the hesiation. If the car is a 99 ,you may have a weak coil.
Old Feb 16, 2004 | 11:47 AM
Keith P's Avatar
I had the situation backwards last night. Coolant too hot compared resistance. Resistance may be too low. 47f to 53f at running temp. After reading astil's responce, I pulled a plug and it does look about the same.
47 to 53 ohms. Considering I'm too sick to be at work right now, check the specs for testing in a manual. Sorry dude.
Old Feb 16, 2004 | 12:27 PM
Well my car isnt running to hot I know that I will check the sensor for sure. One thing I did remember that I had opened up one day and didnt close back fully was the black scren the big plastic one on top of the IACV I think it is.........it was allowing more exhaust gases into the intake tract. thanks
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
