Tech problem please help!!
Old Feb 16, 2004 | 01:21 AM
Shift_my vq's Avatar
I just got my mid pipe intake in. I got it all hooked up except for the whole in the intake pipe with rubber around it, and the air temp sensor. Does the sensor go in there. I tried but it does'nt stay. So now my car runs really funny when it's cold until it warms up. Almost like it's missfiring. but as soon as it get's some heat in it boom it's fine. Guys please help I'm so ****ed
Old Feb 16, 2004 | 01:59 AM
bump please help guys. This is really bumming me out
Old Feb 16, 2004 | 06:06 PM
still broken bump bump up to help
Old Feb 16, 2004 | 06:29 PM
sinewave's Avatar
Sounds like you have a mid-pipe for a '97-99. The ambient temperature sensor for the '95-96 has two small screws to hold it in place, the later ones were just friction fit in a round rubber grommet.
I suggest that you remove the pipe and drill and tap it for machine screws. If you chose to not tap the holes, then make sure you use lock-tite on the nuts. The last thing you want to do is feed a #6 machine screw nut to your engine.
Old Feb 16, 2004 | 06:33 PM
would that sensor not being in there but the hole plugged make my car run funny.???
Old Feb 16, 2004 | 06:45 PM
sinewave's Avatar
I'm not sure but I would think so. It would be sensing the air in the engine compartment instead of the air in the intake. If the air is warmer than what the sensor is reading, your engine would run rich and you would get poor gas mileage. If the air is colder than what the sensor is reading, your engine would be in a lean condition and would probably stumble when the enigine is cold (like right after start-up).
Either way, I think it's worth the effort to do it right and install it.
Old Feb 16, 2004 | 06:46 PM
joaquink's Avatar
¿Hablas Español?
Why won't the grommet fit in the hole? Is the hole too big or too small? Yes, you want it in there and you want it sealed. Drop a little RTV blue/black around it to seal it up properly.
Old Feb 16, 2004 | 06:54 PM
thank you so much guys. Yeah the hole is a little to big but I'm going to parts store right now to buy rtv and a dome light. And that's what it's doing is stumbling a little when it's cold and not on choke. Thanks you guys fuking rock
Old Feb 16, 2004 | 07:02 PM
sinewave's Avatar
Just make sure that you get SENSOR SAFE RTV.
Old Feb 16, 2004 | 08:12 PM
*** I just did it befor I read your post. It doesn't say sensor safe. And it's on there. Am I fuked?
Old Feb 17, 2004 | 03:25 PM
sinewave's Avatar
Most RTV's emit acedic (sp?) acid as they cure and continue to release trace amounts for quite a while. IMHO, I suggest that you get rid of the RTV you just put in, get the good stuff and hope for the best.
Old Feb 17, 2004 | 03:57 PM
ManualMaxima's Avatar
5th Gen till she dies!
jsut stick t somewhere in your bay. i cut a hld on my box and stuck it in there when i installed my JWT. but i know alot of peopl ethat just zip tie it somehwhere in there bay,.
Ben2003GLE
Sep 24, 2015 04:25 PM
maxima297
Sep 24, 2015 01:18 PM
MannyMonroe
Sep 24, 2015 08:45 AM
Pixel
Sep 15, 2015 05:53 AM
