GXE + foglights
okay...just some clarification,
Your 95s could be prewired...it depends on if you have the "comfort package" ie if you have keyless entry, a power driver's seat...then you're prewired. If you don't have those then you are NOT prewired.
good luck
good luck
Found this searching through ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MESSE:IT
Just look under the front bumper for a wire connector taped to the side near the lower signal lights. It's true about depending on the package that came with your car. If your car is prewired then you just need to buy an OEM foglight kit from Nissan that will have all the parts for a nice install.
good luck
good luck
Originally Posted by Kashoggio
to add to this. if your car dosent have the comfort package its still wired but the connectors for the foglights are not there. hte wiring for the switch and relay are there. So you only have to run wires from the relay to the lights
tarun900
19
Dec 20, 2021 06:57 PM
ricky7780
Nov 3, 2015 03:22 PM
