Anyone had problems with control arms???
Old Feb 18, 2004 | 05:21 AM
CPETTY's Avatar
I was wondering how you check to see if the bushings are bad? Any suggestions?
Old Feb 18, 2004 | 05:40 AM
I30tMikeD's Avatar
Are you refering to the ball joint that connects to the steering kuckle?.
Old Feb 18, 2004 | 07:08 AM
mzmtg's Avatar
Minister of Silly Walks
You can visually inspect the bushings for cracks and deterioration.
You can also tell when you drive. If you get the car aligned but it still pulls or wanders. If the car feels insecure in corners. If ridges or crowns in the pavement push the steering wheel around.
My car exhibits all of the above. I have new polyurethane bushings ready to be installed this weekend.
Old Feb 18, 2004 | 07:09 AM
CPETTY's Avatar
Well, I have this clunking noise when going over bumps and thought it might be worn bushings in the control arm.
Old Feb 18, 2004 | 07:19 AM
optimus310's Avatar
that could also be a strut mount. Jack up your car so that the tires are in the air. Open your hood and check your strut mounts. If you see the bushing inside separates it self from the mount housing, then you will need to replace them.
Old Feb 18, 2004 | 08:01 AM
CPETTY's Avatar
If I look where the strut mount is under the hood i see the 3 mounting nuts and the top part of the strut mount with the nut in the center. should i be able to tell with everything bolted together?
Old Feb 18, 2004 | 03:01 PM
optimus310's Avatar
Ok here is a pic. This is a good bushing, this is not an example of how a bad one should look, but you get the idea.
Pretty much make sure that the bushing is in good condition, and if you jack up your car make sure that the bushing always sticks to the housing
Here is a link to a much better quality pic
http://gallery.azmaximas.org/albums/...CN0782_001.jpg
Hope this helps
Old Feb 19, 2004 | 04:32 AM
CPETTY's Avatar
[QUOTE=optimus310]Ok here is a pic. This is a good bushing, this is not an example of how a bad one should look, but you get the idea.
Hope this helps[/QUOTE
That helps thanks, I checked mine it looks good.
Mar 12, 2020 12:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
