weird hum during accel in 5 speed
Old Feb 18, 2004 | 08:43 AM
bashboy2000's Avatar
when i am accelorating my car makes this weird hum mostly in first and second. the hum is more intense if i am accelorating more quickly and more in the first part of each gear(the lower rpms) my friend said this could be my pressure plate but i dont know how much he knows about this problem any ideas on what it is or how hard it is to fix.
1998 5 speed se
Old Feb 18, 2004 | 08:51 AM
Nismo3112's Avatar
Custom User Title
bad differential bearings i'm guessing.
check this out:
http://www.motorvate.ca/mvp.php/804
Old Feb 18, 2004 | 09:14 AM
plurco's Avatar
that is exactly what it is. sorry dude.
Old Feb 18, 2004 | 10:32 AM
what do i do what made it go bad i bought it in november. how much is it going to cost can i do it myself. i read that site that imstockbaby posted but i would like more info please
Old Feb 18, 2004 | 10:51 AM
knight71's Avatar
Check your tires 1st:
I had the same exact noise, everyone told me it was my bearings, I when to a tire shop to get a 2nd opinion, it turned out to be 2 worn/defective tires, replaced tires and the noise dissapeared.
Old Feb 18, 2004 | 11:11 AM
i thought about the tires cuz the were bald but i went and bought 4 new tires and an allignment yesterday and it didnt go away so i posted any more help will be appretiated
Old Feb 18, 2004 | 11:13 AM
Phatmax98's Avatar
1998 5 speed se
I know this may sound dumb..but maybe the alternator? Doesn't it make some sort of funny noise before is goes out?
Also, if you think it might be the pressure plate..does the clutch pedal feel any different...easier or harder to push..just giving suggestions.
Old Feb 19, 2004 | 08:18 AM
I dont think the clutch feels any different but maybe it just grew on me. how would you know if the alt was going out and wouldnt it be at higher rpms that it would whine i dont know im just asking and thanks for the suggestion
Old Feb 19, 2004 | 12:46 PM
Phatmax98's Avatar
The only thing I have heard is that the alternator makes some sort of funny noise before it goes bad. Have you gone to the stealership for the recall?
Check this, if you haven't had the alty replaced.
http://www.nissanusa.com/form/0,,act...-51054,00.html
Old Feb 20, 2004 | 11:01 AM
is there a recall i went to that link and put in my car and it said no recalls. would there be any other signs of the alt going out cuz my lights dont dim the dome lights dont flicker and no idle issues so if there is other signs let me know.
Old Feb 20, 2004 | 11:03 AM
check this out:
is there anything else it could be and how can i know for sure. can i keep driving on them if there bad. i talked to one guy and he said that a car can whine like that for years and be just fine. but i would like more info
Old Feb 20, 2004 | 11:05 AM
nismology's Avatar
It's not your alternator because alternator whine is independant of engine load. In other words, it won't matter if you're on the gas or not. If it's a noise that gets louder if you're on the gas, then it's something in your tranny.
Old Feb 20, 2004 | 12:19 PM
plurco's Avatar
It will eventually get worse. First mine only did it in forst, then first and second, within 3-4 months I could hear it all the way till 5th.
Old Feb 23, 2004 | 10:28 AM
what all had to be done how much did it cost could it be done at home or does a shop have to do it
Old Feb 23, 2004 | 10:58 AM
I30tMikeD's Avatar
Differential bearings may not be the problems since most cases of bad bearings are only the 95 & 96 maxima's. I only know of one or two 97+ maxima's that had the bearings go.
If it is the bearings it's either an expensive tranny rebuild or a huge DIY project. I paid $1700 for new bearings, 3-4 shift assembly, new clutch, and findanza flywheel install. If I did the bearings alone it would have been around $800
Old Feb 23, 2004 | 04:54 PM
sean96SE's Avatar
Also consider wheel bearings, although if the noise varies with RPM and not speed, then I might lean toward the differential.
Old Feb 24, 2004 | 06:29 AM
is there any way to check or should i just take it to a shop? man if thats the problem im ****ed cuz i got this car cuz my last car had tranny problems but i wont dump the max cuz its way too awsome just ticks me off
Old Mar 11, 2004 | 10:27 AM
bumping i need help anyone know any good shops in utah what tests should i have the shops do
Old Jun 10, 2004 | 07:23 AM
yup it was diff bearings. the bracket thats holds the passanger axle in place broke transaxle fell apart now its in the shop bad bearings but im gunna put the limited slip differential in does anyone know where to get one for a good price and quick i need my max back.
bump
Old Jun 10, 2004 | 07:44 AM
MAXRB8's Avatar
Drain your tranny fluid and see what condition it is, put in new fluid and see if there is a change, you may have a slight leak and being low on fluid will increasing the noise level. At least it's cheap even if it doesn't fix the problem. After that if you can live with the noise it may last a long time before rebuild, mine was replaced by the previous owner @ 100k
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Marc2theMax
Sep 28, 2015 08:13 AM
