Rough Idle??????????
Old Feb 18, 2004 | 03:38 PM
eckohb's Avatar
when i come a stop, or brake along at like 1-2 mph, i get really rough ride...i dont know why its doing this. it did it when my stock muffler was messed up, so i got the muffler replaced, and it stopped, but it started doing it again. anyone got any thoughts or suggestions? It's got new bosch plugs thats ive yet to replace, yeah theyre bosch, but still new plugs.
Old Feb 19, 2004 | 07:25 AM
eckohb's Avatar
bump...................
Old Feb 19, 2004 | 07:39 AM
techie's Avatar
I think I have the same thing you're describing. I posted and didn't get any feedback. Mine seemed to start as the temperatures got cold Nov/Dec. It seems better since my trans fluid was changed, but that my be psychological.
If it is the same, you feel it as your coming to a stop,just at the end, below 10 mph? It's almost like when you accelerate fast and have to stop quickly and the transmission is downshifting but the engine take a little longer to come down and you feel the vibration.
Old Feb 19, 2004 | 07:45 AM
eckohb's Avatar
yeah exactly, or when im creepin up behind someone at a stopsign. it feels the same way
Old Feb 19, 2004 | 12:52 PM
techie's Avatar
One thing you can check would be your trans fluid level. Make sure it's topped off. Like I said, it seemed better after my fluid change. I still feel it some but it does seem better. I haven't check the fluid level since the change. I should so a follow-up check myself.
It feels to me like it has something to do with the transmission. I don't know much about the innerworkings of an automatic transmission to guess. Like I said before though, it seems like the rpm's are too high for the gear it's in. Just like what you feel if you wait a little too long to press the clutch in a manual when slowing or stopping.
Old Feb 19, 2004 | 02:33 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Bad Engine Mounts, Bad Spark Plugs, Bad Coil packs, Dirty Injectors. those could cause rough Idle.......
Old Feb 19, 2004 | 02:42 PM
95Max's Avatar
Clean your MAF
Old Feb 20, 2004 | 10:23 AM
techie's Avatar
Originally Posted by 95Max
Clean your MAF
I could understand these things if it was a constant rough idle but the issue I'm talking about, and I think eckohb is talking about, is that there is vibration while decelerating from 5-10mph to stop. Idle is fine otherwise.
Old Feb 20, 2004 | 11:24 AM
95Max's Avatar
More info on vibration. Steering wheel, through the seat, peddles,....
Old Feb 20, 2004 | 11:43 AM
techie's Avatar
As I said earlier, it feels similar to when you hold the clutch out a little to long on a manual trans when stopping. It's a general vibration. Not steering, just slightly all over, generally front end. Nothing destinctive to say, "brakes", "steering", "suspension". It's something related to engine/trans. If I drop it into neutral right before I'm expecting the vibration, I don't feel any vibration.
Old Feb 20, 2004 | 04:27 PM
eckohb's Avatar
yeah exactly. i put it in neutral and it idles fine. im flushing my tranny fluid either tonite or tomorrow, and changing my oil, so we'll see if that has any affect on how the car idles
Old Feb 22, 2004 | 10:14 AM
time2reup's Avatar
do you both have the Bosch plugs??? for some reason the max just doesn't like them sometimes...NGKS
Old Feb 22, 2004 | 01:52 PM
eckohb's Avatar
i just switched back to the NGK coppers yesterday, changed my tranny fluid, and changed my oil to mobil 1...yet to see the idle problem go away...maybe when it all breaks in
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
