just fixed my brakes and..
Old Feb 19, 2004 | 08:45 PM
ShRapNeR's Avatar
Hi,,, I just changed my brake pads and got my rotors resurfaced... while it was on the lift i was looking at the front CV joint and noticed the boot was ripped, thus revealing the acutal joint...
does it really matter that the cv boot is not covering the joint all the way? or should i just put another on there.
don't really want something to possibly get in there and do something harmful.
Old Feb 19, 2004 | 08:48 PM
smokeydriver's Avatar
As far as I know, you should fix that...but I don't really enough to tell ya to trust me on it. Good luck!
Old Feb 19, 2004 | 08:56 PM
ABK's Avatar
ABK
if it was open for a week or two I would just replace the whole axle from autozone. Since all the dirt and $hit will gradually eat that axle away.
Old Feb 19, 2004 | 09:17 PM
ShRapNeR's Avatar
thing is,,, im not sure how long its been like this... i bought the car used about a year ago w/ 96,000 miles. just not have brakes worked on, never really had tires off either.
looks kinda like the rubber is dry rotted, but im not to sure.
Old Feb 19, 2004 | 09:52 PM
ABK's Avatar
ABK
is there still alot of grease inside or is all the grease all over the place?
Old Feb 20, 2004 | 12:41 AM
Stealth Max's Avatar
If the grease is all over the inside of your rim then it is time to replace the whole axle. Better replace the other boot on the opposite side just to be safe.
Old Feb 20, 2004 | 08:58 AM
ShRapNeR's Avatar
no.. the grease is still on the joint, the boot is only ripped halfway around closest to the wheel
* how much do these cost anyway?
Old Feb 20, 2004 | 09:20 AM
lefty
How easy of a job is it to change out the boot yourself?
I may just change mine even thought it is not ripped jsut to be sure I don't have an expensive repair later.
Is this a good thing to do?
Old Feb 20, 2004 | 09:29 AM
dmplus's Avatar
It's been a while since i replaced my cv axles, i think for both it was like 200 bucks or something
Old Feb 20, 2004 | 09:34 AM
Jatan's Avatar
I had both of mine done at a shop for $230. The labor is the same to replace the boot or the entire axle so replace the axle and you won't have to worry about covering up a bad axle.With almost a 100k miles, the axle is probably weak by now so just replace the whole thing.
Old Feb 20, 2004 | 12:01 PM
Brudaddy's Avatar
You went a year without even taking your wheels off? How did you do that? I mean, didn't you change your pads or rotate your tires or anything?
Old Feb 20, 2004 | 01:01 PM
RyCrisp's Avatar
I'd replace the entire axle...might as well do both of them to be safe, it's cheap enough. Go with raxles...just got mine delivered a few days ago, they were 119 for one side and 149 for the other, forgot which one was more expensive. They're supposedly better than stock.
Mar 12, 2020 12:06 AM
Mochedda
Dec 15, 2015 11:27 AM
05RLS2
Sep 27, 2015 09:24 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
hozay99
Sep 19, 2015 10:20 PM
