As the subject states, where are you shifting to get optimum gas mileage? For my daily commute, I try to shift below 2300 rpms for every gear. My car still is not giving me great range on a full tank. I know there are many other factors that come into play with gas mileage, but I am only focused right now on the shifting.
dump the 18's and stereo equipment.
I shift right around 3-3.5k, my car doesn't like being shifted at low rpms...I get about 300-350 per tank at this rate
Quote:
Well the 18's haven't even gone on the car yet...and they are not exactly boat achors either (18.6 lbs a piece).Originally Posted by SteVTEC
How much of that is highway driving? I get about 225 mpg on my auto with mostly city.
shift at like 3- 3.5 this is the optiumum rpm range for cruising for the maxima.. below that you are probably running a little rich on acceleration.. above that the rpms is too fast to get good milage.
i average 22-24 mpg.
Quote:
Originally Posted by geo1317
look in your owners manual, it tells you when to shift in there.
it does? too bad i dont have mine... so what does it say?
Quote:
i wish i knew where mine was too, i just remember seeing it in there.
Quote:
Not a whole lot of highway around here...so I don't know how your mileage is low. Do you drive aggressively? I do, but it's not that often.
Quote:
Do you mean 225 miles per tank? If so, that is LOW.Originally Posted by s3roush628
i dont have a stick on my maxima, but my other car (not mine, my parents) ive driven a while back (a GT) and i shifted at 3000 RPMs and got pretty good milage
I always try to shift before 3k rpm. I get pretty bad gas mileage. I get like 250-300 on 16 inchers.
Maybe I'll try shifting around 3500 rpm.
i shift at 3.5 as well, i would rather waste gas then have to think about granny shifting every time i do it....that is too much thinking
Thats right kingrukus, only 225 miles per tank:-(. Its all city driving in my automatic thoughL
I dont top off though and try not to run it to low fuel light. Is there something wrong with my maxi?
I dont top off though and try not to run it to low fuel light. Is there something wrong with my maxi?Newbie - Just Registered
Quote:
It says suggested maximum speed.Originally Posted by PLUMMAXSE
Hell I did 100 in 3rd in mine? Guess the book doesn't mean that.
Quote:
I've gone past 100mph in 3rd as well.Originally Posted by nismos14
r u sure? i can't do 100 in 3rd in my 5 speed
[edit]Oh, yeah...I keep it between 2k and 3k when I'm being nice
[/edit]never pass 3,000rpm all gears. 320mi/tank with 50% local 50% hwy driving w/ ghost 0304 CEL
. mobile 1 sythentic 5W/30 + OEM nissan filter + 91 octane.
. mobile 1 sythentic 5W/30 + OEM nissan filter + 91 octane.For those you that can go over 100mph in 3rd, either you're an automatic or your speedometer is off. It's impossible to any faster than ~96mph in 3rd with the stock rev limiter
With my 7000rpm limiter, I can only do ~102mph in 3rd.
As for shift points and MPG, I shift my 1-2 at approximately 4000rpms, the 2-3 at ~3800rpms, and the 3-4 at approximately 3000rpms. A lot of the time I go directly from 2nd to 4th. I tend to play around in 2nd and 3rd quite a lot revving it to 5000-6000rpms a few times a day. I usually get 22mpg with 80% city and 20% highway. I usually get 26-27mpg in straight highway driving.
Dave
With my 7000rpm limiter, I can only do ~102mph in 3rd.As for shift points and MPG, I shift my 1-2 at approximately 4000rpms, the 2-3 at ~3800rpms, and the 3-4 at approximately 3000rpms. A lot of the time I go directly from 2nd to 4th. I tend to play around in 2nd and 3rd quite a lot revving it to 5000-6000rpms a few times a day. I usually get 22mpg with 80% city and 20% highway. I usually get 26-27mpg in straight highway driving.
Dave
Quote:
What makes you say that?Originally Posted by Dave B
I get between 300-350 on a tank of 91. And the way I do it is I skip gears. I start out in first or second, and shift to 4th or 5th gear. And don't floor it just give it a second and it gets there. And I just took the car for a spin and I did 100 in 3rd gear????
i used to get almost 400 for the tank with CAI and using mobil 1 synthetic shifting at 2800 or so, but now, after going to non-synthetic and gettin full exhaust and gettin a weird CEL 0305 i think, i barely get to 290, but the weather changed so i dont know what exactly caused it
I pride my self on gas mileage. Within the next few months I will be changing plugs/fuel filter, ripping out stock intake system with dirty air filter and replacing with clean franken car system, replacing stock b/y with aftermarket b/y and cleaning cat. Hopefully with that, and under regular driving, my range per tank will sky rocket. Right now I can get about 340miles (~550km) per fillup if I am lucky and take it right to the low-gas warning light.
Holy crap! I drove 265 miles recently..mostly highway and only used half a tank! I noticed this tonight when I went to the store tonight. Oh and BTW I have 2 codes for my SES light. So...265 x 2 = the other half of my tank is what..about 530 total? All I can say is wow.
That's a very inaccurate way to measure mileage. Here's the best way:
Fill up; reset trip meter; drive a lot; Fill up
Take the mileage on the trip meter and divide by the number of gallons on the 2nd fillup.
If you're really hung up on accuracy, use the same pump for both fillups.
Quote:
It's a pretty easy calculation. Every 1000rpms in 3rd gear equals 14.9mph. 14.9mph times 6.5 (the stock 6500rpm rev limiter) equals a maximum speed of 96.85mph in 3rd gear. It's impossible to go any faster in 3rd without a raised rev limiter. Originally Posted by sryth
At 6500rpms:
1st 37mph
2nd 66mph
3rd 97mph
4th 129mph
5th 153mph
http://www.boostaholic.com/maxima/dyno/shiftpoints.html
Dave
Quote:
I wouldn't put much faith in measuring that way. The gauge is slow to react. I'm currently at 120 miles and have only used a 1/4 tank. I know for a fact that my car will not be getting 480+ miles on a tank. Originally Posted by Phatmax98
Dave
Quote:
Dave
I wouldn't put much faith in measuring that way. The gauge is slow to react. I'm currently at 120 miles and have only used a 1/4 tank. I know for a fact that my car will not be getting 480+ miles on a tank. Dave
Yeah..the best I have actually got was around 400 on a fillup...but it's nice to dream
Quote:
At 6500rpms:
1st 37mph
2nd 66mph
3rd 97mph
4th 129mph
5th 153mph
Dave
Pretty good link!Originally Posted by Dave B
It's a pretty easy calculation. Every 1000rpms in 3rd gear equals 14.9mph. 14.9mph times 6.5 (the stock 6500rpm rev limiter) equals a maximum speed of 96.85mph in 3rd gear. It's impossible to go any faster in 3rd without a raised rev limiter. At 6500rpms:
1st 37mph
2nd 66mph
3rd 97mph
4th 129mph
5th 153mph
Dave
As for the speed, I get different numbers. Again, it all depends on tire inflation.
Code:
[edit]If anyone wants the Excel file for this, PM me.[/edit]F 3.823 Input Axle Tire: 215 55 16 1 3.285 0.304 0.080 Height: 25.31 2 1.85 0.541 0.141 Circumference: 79.52 3 1.272 0.786 0.206 4 0.954 1.048 0.274 5 0.795 1.258 0.329 R 3.482 0.287 0.075 Axle Revolutions 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 6550 1 80 119 159 199 239 279 319 358 398 438 478 518 522 2 141 212 283 353 424 495 566 636 707 778 848 919 926 3 206 308 411 514 617 720 823 925 1028 1131 1234 1337 1347 4 274 411 548 685 823 960 1097 1234 1371 1508 1645 1782 1796 5 329 494 658 823 987 1152 1316 1481 1645 1810 1974 2139 2155 R 75 113 150 188 225 263 300 338 376 413 451 488 492 Wheel Speed 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 6550 1 6.00 8.99 11.99 14.99 17.99 20.99 23.98 26.98 29.98 32.98 35.98 38.97 39.27 2 10.65 15.97 21.29 26.62 31.94 37.26 42.59 47.91 53.23 58.56 63.88 69.20 69.74 3 15.48 23.23 30.97 38.71 46.45 54.20 61.94 69.68 77.42 85.17 92.91 100.65 101.43 4 20.65 30.97 41.29 51.62 61.94 72.26 82.59 92.91 103.23 113.55 123.88 134.20 135.23 5 24.78 37.16 49.55 61.94 74.33 86.71 99.10 111.49 123.88 136.27 148.65 161.04 162.28 R 5.66 8.49 11.31 14.14 16.97 19.80 22.63 25.46 28.28 31.11 33.94 36.77 37.05
why does it depends on tire inflation? Are you guys refering to the actual speed the car is going or just what the speedo says? If your saying actual speed, then yeah I see where tire inflation/size comes into play but that would still be an inaccurate equation unless you measured the tires circumfrence when its spinning because I think the tires would balloon a little depending on the rpm.
