Service Engine Soon light is on
Old Mar 12, 2001 | 01:58 PM
Bernie Lomax's Avatar
Can someone help me find the link to the code thing? It just came on and I'm at just over 75K miles. What could my problem be? It's running fine as far as I can tell. Just had the oil changed.
Old Mar 12, 2001 | 02:04 PM
Daniel B. Martin's Avatar
You will find instructions to do a DTC readout and reset
the Check Engine light at:
http://vbxmaxima.8m.com/ecu.html
The DTC "translations" are found at:
http://vbxmaxima.8m.com/ecudecoder.html
Old Mar 12, 2001 | 03:03 PM
That's exactly what I was looking for, thank you!
Old Mar 14, 2001 | 10:29 AM
Now I'm worried
The light was on for 2 days and before I could check the code, it's shut itself off.
Should I be worried?
Old Mar 14, 2001 | 11:01 AM
Don't worry, be happy!
It is normal for some problems to "go away". The loose fuel cap code is an example.
Do a Diagnostic Trouble Code readout. The codes may still be accessible.
Old Mar 14, 2001 | 01:31 PM
Chebosto's Avatar
RIceD OuT moDErAtor
Re: Don't worry, be happy!
complete MIL code is
in MaxTech under TECH at MaximaDriver.com.
Old Mar 14, 2001 | 01:35 PM
Jeff92se's Avatar
I'm needing a caw
Even though the light is off, the code should be available for a certain amount of ignition key turns. I think the ecu will store the code for about 50 turns of the ignition key. After that, if it doesn't see the same error code, it will erase it. I'm not too sure what the exact # of key turns clears the memory though. Just run the diagnostic asap to make sure you can still get it for future reference.
Old Mar 14, 2001 | 01:53 PM
Chebosto's Avatar
RIceD OuT moDErAtor
Re: Re: Don't worry, be happy!
http://www.bol.ucla.edu/~cchiu1/ecuerrorcodes.html
Old Mar 15, 2001 | 08:16 AM
Re: Re: Re: Don't worry, be happy!
Thank you, guys. I will check it over the weekend. I only start the machine twice or three times a day, so I should be all set. I'll check it over the weekend.
vingodine
45
May 21, 2016 12:46 PM
rbaker100
Aug 28, 2015 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
