guys need help please,!! with e-bay upgrade headlight harness
Old Feb 23, 2004 | 04:38 PM
maximalnemisis's Avatar
hi I bought a headlight upgrade harness w/relays from e-bay and I ve talked too a few people and they said you cant just plug and paly you have too match the stock headlight harness wires too the new harness wires form the upgrade kit! how do you take the wires out of the e-bay kit too change them around and also whats the order I have too put them in?????... i need help because one side ( the pass.) is starting too melt again could this be becuase the wires have too be switched and they are not propely switched? also my high beam indicator is always on and I have no high beams
Old Feb 23, 2004 | 05:48 PM
ManualMaxima's Avatar
5th Gen till she dies!
do you have a burned out bulb
Old Feb 23, 2004 | 06:28 PM
yes and I checked the harness and its starting too melt
Old Feb 23, 2004 | 06:41 PM
ch13f's Avatar
Stop using rice bulbs. You shouldn't need any new relays, just cut the plug off your stock harness connect and the corresponding wires.
Old Feb 23, 2004 | 06:50 PM
yeah you are right they are such a waste of money and time but I want more lighting w/out buying hid.. and yeah I know how too cut and spice the wires but I need too know from a person that has went through this and can help me through their experience thanx
Old Feb 23, 2004 | 06:55 PM
felix's Avatar
Sittin' On Chrome
i just upgraded mine... what do you need to know?
Old Feb 23, 2004 | 07:03 PM
o.k on the ebay harness there are a set of colored wires(3) and the same on the stock harness...a low, high, ground... well apparently there is an order too the way these connect, a specific order. some say you have too open up the e-bay harness and rearrange the wires. I need too know this order, instead of standing out there and guessing all day thanx
Old Feb 23, 2004 | 07:08 PM
felix's Avatar
Sittin' On Chrome
all I did was cut off the old harness, and hard-wire the new one to the 3 colored wires. dont worry about the order, just match up the position (left, middle, right).
i guess that would be the order.
Old Feb 23, 2004 | 09:07 PM
Angelr34's Avatar
mine had different colored wires but they come out the end in the same order as the stock ones so there should be no problem.
Old Feb 24, 2004 | 12:47 PM
Brudaddy's Avatar
where is a good place to get a quality upgraded wire harness for fogs and headlights?
vingodine
45
May 21, 2016 12:46 PM
JMag90
Aug 25, 2015 09:17 AM
maxipower
Aug 21, 2015 11:10 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
