Do any 4th Gen's have ABS?
i searched the FAQ's with no luck (unless i missed it). And i know my car 97gxe does not have it, but when i looked on autotrader, a 98 had it advertised. I just would like to know if any of the 4 gen's have them, and what years, and if so, is it on all car's, or is it an option.
its was a stand alone option on all 4th gens, but did not become standard till the 5th gens
A stand alone option on all years of 4 th gens, But it was like 999 dollars, so it was pretty pricey. Probably most likely on GLEs or SEs, though I remember seeing ~30K GLEs with sunroofs, but no ABS ordered, on dealer lots in 1999
Originally Posted by CystumMax
It is Standard on all GLE..... And optional on SE and GXE.
just FYI...
I have it on my 99. I believe it was an option as well.
I wish my 97 had it, I will eventually try and convert to ABS. My 92 has it and I can tell a big difference in the braking and I believe the 3rd and 4th gens both have the same brakes, I am about 95% sure of that and I know the 4th gen is like 100lbs lighter so that has to be the reason for the better braking. I know that ABS equipped Maxs have bigger master cylinders also.
Originally Posted by SuperChris
negative...optional on all trim lines, and unavailable on GXE's with manual.
just FYI...
just FYI...
I Made a mistake because the sales man lied to me. My car has ABS he told me all GLE's come with it......
Originally Posted by MaximaTodd
how can you tell if you have ABS or not? the dealer i bought it from said it did, but nowhere in the documentation does it say anything about abs. =l
It is right hand side on the top corner. it is like cylinder box with some metal tube going into it, its like four of them (For the four wheels). Also when there is snow or ice on the road and you break you feel machine gun under your feet. And it makes this wired noise and you know you are not skidding.
would u point at it in the pic?
If you've got ABS, then you'll have a light come up on your dash. Unless all have this light, with or with out (which would be misleading if so).
Anyway, here in New Zealand, all 4th gens came with ABS standard, airbags, how ever were optional, as mine does not come with any
Originally Posted by 007max
i say screw ABS... of course i never drive on ice or snow so what do i know right
Yup...ABS was an option on my 98 SE...I don't have it though. I didn't want it at the time, but it may have saved me from a fender bender in which I didn't modulate quickly enough. If I had it to do over again I would probably get it.
yeah, most of what people misunderstand about ABS is that they think it makes you stop quicker and shorter. Not necessarily. It might make you stop more quickly, if you are in a skid or something, but it may not. What it does, however, is help you to maintain control in a harsh braking situation and still be able to steer. It would have been very helpful to have in a couple of my wrecks over the years.
MAXSE5SPD
Sep 17, 2022 04:00 AM
