Cefiro headlight install write up
Old Feb 24, 2004 | 11:40 AM
BlueBOB's Avatar
I have been trying to search and find this info but the search isn't acting right and I can only search for one word.
Does anyone know of a Cefiro headlight install write up, or can anyone just give me a few pointers... i'm looking into getting a set and I am curious what I need to modify to make them fit.
Old Feb 24, 2004 | 01:35 PM
BlueBOB's Avatar
:attention
Old Feb 24, 2004 | 01:43 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
Cefiro One-Piece Headlight Installation Instructions
1. Remove the stock headlamps by removing the 8mm nuts from behind. Remove the lamps. Unscrew the Phillips head screw from the top of the corner lamp and pop the corner lights out. Save all the hardware, you will use it in the installation
2. Unscrew the black trim pieces off of the bumper. This is to allow more room for the one-piece light.
3. Take the Cefiro headlight and test fit it up to the car. There is a bracket in the way of proper fitment. Take a marker and draw on the bracket of where you would like to cut the bracket. Remove the headlight and set it aside.
4. Make sure that you have proper eyewear and take the Dremel with a cutting wheel and cut along the line that you made for the bracket. You may have to use several to get through the bracket. Also, there are some tabs on the fender that you should cut off. If you want to put the Grinder attachment on the Dremel to smooth the edges, you may. You might also consider painting all cuts with primer so they don’t rust.
5. Once the bracket and the tabs are cut off, test fit the headlight again. This time there is a welded joint inside the fender that gets in the way. Cut in a crescent shape to allow room for fitment. I hammered it too to smooth out those edges.
6. Test fit again and again to try and get the best fit. If the gap in the fender is not to your liking, you can grind the part of the car where the bolts fit through and are attached with the nuts. Grind in a smooth circular motion on those two holes as well as the larger one where the adjuster nut sits. (You will only need about ¼ of an inch to get the headlight over a little more.)
7. Take the exhaust hanger strip
Old Feb 24, 2004 | 01:50 PM
BlueBOB's Avatar
That's a great start! Thanks!
I guess I'll be doing a write up with pics when I do my install...
Old Feb 24, 2004 | 02:44 PM
JNCoRacer's Avatar
Just the tip.
You suck, Chris.
Old Feb 24, 2004 | 02:47 PM
BlueBOB's Avatar
Originally Posted by JNCoRacer
You suck, Chris.
Old Feb 24, 2004 | 02:55 PM
ptatohed's Avatar
Licensed to Spell
:o)
A question mark at the end of your thread title would be appreciated in the future.
Old Feb 24, 2004 | 05:42 PM
vsamoylov
ok, now if i get these, will they fit a 96 maxima? i know you have to do some work butt i read somewhere that i need a 97-99 maxima grill? is that true? and do u guys think it is worth getting them?
Old Feb 24, 2004 | 05:52 PM
darrick's Avatar
Dallas Nissan Enthusiast
chris im down to do mine at the same time when are you getting yours in?
Old Feb 24, 2004 | 07:34 PM
BlueBOB's Avatar
D? you gettin them too!?!?
vsamoylov,
I'm not sure about the 97-99 part, but i'll be sure to let you know as I have a 95.
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
