directions for cutting the nubs on the corner light lightbulbs (next to headlights)
Old Feb 24, 2004 | 06:35 PM
95maxcntrljrsy's Avatar
i looked in faqs and how tos - but could only find the rewire for the clearance lights (lights in bumper near turnsignal)
Old Feb 24, 2004 | 06:36 PM
happyricefob's Avatar
V^___^V
Stuff you need: Phillips head screwdriver, flathead screwdriver, nailclippers, electrical tape
1)Remove your clearance light housing. It's pretty simple, just pop the hood and remove the screw that holds it in. With a little bit of tugging, you can pull the side closest to the doors (not the front side) out (it goes behind a little plastic flap). look down into the hood and find the little ball joint socket that holds the clearance light in. take a screwdriver (flathead) and pop it out of that socket. there the light is out.
2)Remove the bulb from the light by twisting it and pulling it out. Place the clearance light housing onto the ground.
3)In your hand you should have the bulb in socket connected to the wires for it. The bulb can be removed from its socket by being twisted and then pulled out. do so now.
4)Look at the bulb closely. On the metal base (below the glass) you can see two metal "nubs." Take fingernail clippers and snip the one CLOSEST TO THE GLASS (the higher one).
5)Cut a strip of electrical tape about 2 inches long and 1/4 inch high. Wrap this tape around the spot where the nub was so that it covers the spot (but not the other nub). This is to ensure a secure connection in the socket.
6)Look down into the socket of the bulb. You can see two notches where the nubs were to be secured (one for the higher nub and one for the lower nub). The bulb, however, now has only one nub (the lower one). Heres the tricky part: you want to put the bulb in so that the lower nub (the remaining one) goes in the spot that the higher nub was supposed to (dont worry if the electrical tape gets pushed a bit).
7) Now that the bulb is back in socket, replace the socket in the housing but dont put the housing back on yet. Flip your lights on to make sure that the job worked (I haven't seen it fail when you use electrical tape). Once your confident that it worked replace the housing (make sure its in there!).
8)Repeat on other side.
credit: maximadriver.com
Old Feb 24, 2004 | 06:37 PM
myke321's Avatar
Cut the nub on top, (highest)
Old Feb 24, 2004 | 06:43 PM
Max Noob's Avatar
i just rubbed the nub and sanded it down against the concrete curb. took about 10 seconds... worked great..then put on a lil piece of electric tape and your good to go..
Old Feb 24, 2004 | 06:47 PM
do they burn out quicker - or burn out fuses quicker?
Old Feb 24, 2004 | 09:50 PM
Max Noob's Avatar
no..the wiring was meant to hold that voltage..so you should be fine..i havnt had problems.. here are some pics.
Old Feb 25, 2004 | 06:13 AM
Torgus's Avatar
one of mine recently burnt out but i havn't heard it as being a problem...and i'm pretty sure the one that burt out was the one i accidently touch =]
vingodine
45
May 21, 2016 12:46 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
KristyKarina
Aug 23, 2015 09:53 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
wingsfan24
Aug 15, 2015 07:35 PM
