code 07 05 EECS
Old Feb 25, 2004 | 09:37 AM
ssilva420's Avatar
code 07 05 EECS
Diagnostic Trouble Code 0705 points to a problem with the Evaporative Emission Control System.
How important is this to get fixed? has anyone ever had this code pulled up on thier car? what did you do to fix it?
Some one give me some advise.
Scott
Old Feb 25, 2004 | 09:43 AM
96white's Avatar
I had it on my car, You have to replace the vent canistor control valve. Your car will run better once its fixed, gas milage may go up.
Old Feb 25, 2004 | 12:39 PM
Kevlo911's Avatar
Kevlo for President
0705
This malfunction is detected when the EVAP control system has a leak or the EVAP control system does not operate properly. (EVAP = EVAPorative emissions.)
Possible causes include...
- incorrect fuel tank vacuum relief valve
- incorrect fuel filler cap
- fuel filler cap vent remains open or fails to close
- foreign matter caught in fuel filler cap
- a leak in the line between the intake manifold and the
EVAP Canister Vacuum Control Valve
- foreign matter caught in the EVAP CVCV
- leaks in the EVAP canister or fuel tank
- leaks in the EVAP purge line (pipe and rubber tube)
- EVAP purge line rubber tube bent
- blocked or bent rubber tube to EVAP control system pressure sensor
- loose or disconnected rubber tube
- EVAP CVCV and circuit
- EVAP Canister Purge Volume Control Solenoid Valve and circuit
- absolute pressure sensor
- tank fuel temperature sensor
- MAP/BARO switch solenoid valve and circuit
- blocked or bent rubber tube to MAP/BARO switch solenoid valve
- O-ring of EVAP CVCV is missing or damaged
- water separator
- EVAP canister saturated with water
- EVAP control system pressure sensor
- refueling EVAP vapor cut valve
- ORVR system leaks
This is a "jackpot" DTC. It points to so many things you don't know what to check. It is often combined with another DTC which is more specific and therefore more helpful.
http://forums.maxima.org/showthread.php?t=265311
Old Feb 25, 2004 | 05:55 PM
ssilva420's Avatar
ya i read the FAQs for the 4th generation. i saw all the other things it could be i just was wondering if anyone else had hit the nail on the head with out seeing which of the items listed in the FAQs actually triped the check engiine light...
How much did the canister control valve cost you and how hard was it to put in.
scott
Old Feb 25, 2004 | 06:03 PM
96white's Avatar
To be honest i dont know, because I get a discount for working at a stealer ship. Normal price should be under 80-90 $ . Its not hard to do , I had my mechanic do it in 1/2 hours and that includes taking rusted bolts off. It shouldnt take more then 1 or 2 hours depending on your skills, and if you have a lift for your car, or jacks or anything else.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
