O2 sensor problem.....need help ASAP
Old Feb 25, 2004 | 01:55 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
okay any and all help is greatly appreciated.
MY problem:
After scanning the car with an OBDII scanner, i pulled code P0135. This is the equivalent of 0901 if you use the self-check system. This code is the upstream oxygen sensor heater fault.
Now after researching this a little here (it's post # 17). I've come to realize that it's either the harness, or the sensor itself.
now here are my questions:
1. The harness is what plugs into the electical connector on the car itself, correct? What i mean, is that, if the harness is bad, the O2 sensor needs to be replaced, right? OR is it something else, and if so, where can i get info on that?
2. The problem sensor in this picture is the one in the most top-lefthand corner of the screen, right? The one with the "(RH)" after it.
3. IF i have to replace the sensor, where can i get it cheapest?
4. In searching for a good price, i checked oxygensensors.com. I'm a little confused, because according to their website the problem sensor would be the one described as "Sensor located in front manifold/exhaust pipe before catalyst on right side" (right?). Now there are 4 different choices, 3 of which have 3 wires, one has 4 wires. I'm not even considering the universal, because that involves cutting and splicing wires. How do i know which one i need, considering that they're all "OEM"?
PLEASE PLEASE PLEASE HELP!!!!!!!
PS> THe car is cali-spec. Any other necessary info can be given.
Old Feb 26, 2004 | 02:25 AM
bump....anyone?
Old Feb 26, 2004 | 01:05 PM
dammit
1234567890
Old Mar 3, 2004 | 05:00 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Just call DAVEB at South Point Nissan and he'll get you all squared away, and also give you a good price. Tell him you're from the ORG.
888-254-6060
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
