Tire pressure measurement at what temperature?
The recommended tire pressure posted under the armrest for the 99 model is 29psi but I wanted to know at what temperature is that measured at. I need it to adjust the pressure accordingly with the decrease/increase of air temp which I believe ~1psi/10F.
Originally posted by breaux124
You supposed to check the pressure when the tire is "cold" Basically, that means when you haven't driven more than a mile or two on them, or that they haven't been driven for about three hours.
Yeah, I checked mine at home and then drove to the gas station to fill them up. The pressure went up 2psi all the way around in that 10 minute drive. I know its not totally accurate, but what I do is measure at home, then note where each tire is and then add that much when I get to the pump.
Yes the 29psi is for cold tire measurement. But that "cold" factor is related to the tire itself and not the ambient air temperature. If the tire pressure was at 29psi last summer, at 70F, then this winter at 30F the pressure would probably drop by ~4psi. So I'm assuming that by knowing at what air temperature that 29psi was recommended at then I can adjust it accordingly to climate changes.
what psi do you run your tires at? i know the recommended pressure is 29psi, but that leaves for a soft, mushy feel.
i run my tires at 35 psi. i have two of the original rs-a and two dunlop sp sport 8000. fyi, the tires are wearing evenly, and the car feels more responsive (more bumps too, but makes it feel more like a sports sedan...).
Aren't you supposed to bump it down so you can get better traction in snow?
According to the panel under the front armrest, my 1997 SE is supposed to have 32 in the front and 29 in the back. I bumped it up 1 psi all around during the winter.
Actually, some people believe that if you decrease your standard tire pressure below factory specs that you'll get better traction in the snow, but that isn't true. Because you have a larger surface area touching the snow. Consider the traction ability between 8" wide tires and 5" wide tires in the snow.
AaronL
11-15-2020 11:52 AM
RWCreative
09-21-2015 11:01 AM
Serotta33
09-17-2015 12:14 PM
