98 Maxima v.s Spec V
Old 02-28-2004 | 06:28 PM
dss42's Avatar
How fast are these new sentras?
I know they have much better handling then our maximas but anyone know who would win in a 0-60 race?
btw.. 5 speed maxima.
Old 02-28-2004 | 06:35 PM
MDeezy's Avatar
I would guess the Spec V sentra, its has 165HP, and 175lb-ft torque about 25HP weaker, but the sentra I'm sure is much lighter than us Max's tipping the power to weight scales in their favorite.
sadly I would say the Sentra, thats assuming its going against a stock Max, if the Max is modded then its a new story.
Old 02-28-2004 | 06:38 PM
Wisky97SE's Avatar
I would disagree. . . with equal drivers the 5-speed 4th gen Maxima should beat a Spec V. Specs with an awesome driver can probably run a 15.4 , a 5-speed max with an awesome driver should run 15 flat.
Old 02-28-2004 | 06:39 PM
KsuMax's Avatar
Cheesing away...
max would win
Old 02-28-2004 | 07:01 PM
MONTE 01&97 SE's Avatar
Max should take it
Old 02-28-2004 | 07:09 PM
nismology's Avatar
I've never heard of stock Spec V's running high 14's...
Old 02-28-2004 | 07:12 PM
nismos14's Avatar
§è~® f®ÈÄk
i raced one the other day in the rain tho and it sucked cuz i got so much wheel hop. they have no high end cuz i pulled on her after shifting into 2nd at 4k rpms, and by 3rd gear i was past her
Old 02-28-2004 | 07:45 PM
MaximaTodd's Avatar
G
they give the max a good fight. check out this video.
Right Click 'Save As'
http://maximaspeed.web1000.com/video/maxvsspecv.avi
Old 02-28-2004 | 07:55 PM
dss42's Avatar
I raced one tonight.. But it was on a bad road that was curvey. I ****ed up 2nd gear kept my foot on the clutch too long so he took me. Not sure if he was stock.. I have : Y-pipe, Catback Exhaust, Injen CAI, Fidanza Flywheel, Race pipe and an ACT clutch. I dont know why but I feel my low end power is weak or atleast is really bad because it pulls me to the side when I floor my car it used to bunny hop and peel out now it does not do that lets me take her to 6.5k with no problems.
I know for sure that 2gear at 3k rpm I can take a sentra but not sure about 1st gear.
He might of been on the good side of the road and I was just on pot holes.
Old 02-28-2004 | 07:59 PM
nismos14's Avatar
§è~® f®ÈÄk
sick vid, who's car is the max? i can't believe the third run the spec- v had it for so long
Old 02-28-2004 | 08:12 PM
MaximaTodd's Avatar
G
yeah the vid is sweet. im not sure whos max it is. definetly not mine. but that spec v sure gave him a run for his money!
Old 02-28-2004 | 10:16 PM
nissanguy's Avatar
By the numbers, car and driver did a 0-60 in 6.6 with a new 5 speed 95 Maxima se, I ve seen low 7's with a spec V. Weird because it seems like the V should win with 20 less HP but about 300-500lb less weight? I really don't like that tranny linkage of that specV, very notchy, my max has a much better shift feel, my old classic SE-R had a really nice shifting tranny though.
Old 02-28-2004 | 10:40 PM
Maxima99SE's Avatar
will fly for food
se-r spec-v is 175hp, se-r is 165hp
Old 02-28-2004 | 11:21 PM
Nealoc187's Avatar
SLOW
Spec Vs put down about 145whp and 155tq stock, give or take a few. They weigh 2700lbs dry. Divide it the numbers and you get 18.62lbs/hp and 17.42lbs/tq.
Typical 5spd max puts down 165whp and 175tq stock. The max weighs between 2850 and 3000 depending on year and model and options. Lets give the Spec V the benefit of the doubt and use the heavier max, 3000lbs. Division gives 18.18lbs/hp and 17.14lbs/tq. As you can see the maxima, even the heaviest maxima, has a 2.4% power/weight ratio advantage, and 1.6% tq/weight ratio advantage. These are of course peak numbers and they don't mean everything, but they give you some idea of what we're working with.
I also hear that the gearing of the Spec V 6spd tranny is less than ideal and that doesn't help matters much if that is the case. The maxima has damn near optimal gearing for it's stock power curve so there's another advantage to the max.
All this contributes to the max being a bit quicker than the spec V.
Old 02-28-2004 | 11:26 PM
happyricefob's Avatar
V^___^V
SE-R spec V w/ 6speed runs mid-high 15s stock. 4th gen maxima auto runs about mid 15s stock, 5spd with low 15 possibly high 14s stock w/ skillful driver.
i raced a spec V one time w/ intake y-pipe muffler and pulled about 1 car length by the end of my second gear. i'm auto. and it was a long time ago.
Old 02-28-2004 | 11:29 PM
V^___^V
SXN's 97 GXE auto stock put down 146WHP 2 weeks ago on the dyno. i doubt the 5-spd put down 165whp stock though. maybe 155whp-160whp.
either way the conclusion is 4th gen maxima is faster than SE-R spec v.
Old 02-28-2004 | 11:38 PM
Nealoc187's Avatar
SLOW
There are no stock 4th gen dynos that I could find in the dyno slip forum, but I've read of people putting down more than 160whp stock in 4th gens. Lordrandall put down 163whp in his bone stock 92 VE even. I'd say anywhere between 160 and 165 would be normal. 155 is low, that would be 19% drivetrain loss, that's more than a manual transmission loses. 165whp would be 14% loss. Typical manual transmission losses are about 15% so 165whp is pretty accurate.
Old 02-28-2004 | 11:50 PM
V^___^V
hrmm..
yea i overlooked at other people's dyno. mai bad
Old 02-29-2004 | 09:04 AM
nissanguy's Avatar
I thougth that 4th gens weighed over 3000lbs even 3200? I have leather abs 5 speed SE 96
MAXSE5SPD
08-23-2015 12:06 PM
Turbobink
08-15-2015 07:20 AM
Supragte
08-12-2015 10:00 PM
Team STILLEN
08-10-2015 04:29 PM
Quick Reply: 98 Maxima v.s Spec V
