Buzzing/Rattling Noise from shifter area after y-pipe install
Old Mar 1, 2004 | 08:57 AM
D1NOnly34's Avatar
Well after, I installed my Warpspeed y-pipe, I've been getting this noise that seems to be a mix of buzzing and rattling comming from my shifter area. It does nto happen all the time, it comes and goes, usually occurs when I press the gas a lot more than normal. The noise stays there for about 2 seconds, and then goes away till I press the gas, again, what could this be? I'm assuming that right under the shifter area is the flex section of the y-pipe. Is this normal? Ive had my pipe on for a week, but the car hasnt been driven much due to some other problems. Let me know, thanks
Old Mar 1, 2004 | 11:32 AM
bignick's Avatar
Most likley its the heatshield rattling. Bring it to a exhaust place or check yourself to see if its rubbing anywhere.
Old Mar 1, 2004 | 11:52 AM
smokeydriver's Avatar
i can tell ya i had that EXACT same problem. rattled at about 3000 RPM. To fix it...go have fun in your max! Go on some nice back roads, and haul! After I did that, the flex section was nicely broken in. I raced around on back roads w/ my roomate in his Pontiac GTP for about 10-15 minutes. That solved it. That was the most fun fixing my car I've ever had! Good luck!
Old Mar 1, 2004 | 01:47 PM
Shift_my vq's Avatar
He's so right I Had the same problem till i just drove the **** out of my car for a few days and poof gone. And trust me you will have no problem wanting to drive fast after y pipe
Old Mar 1, 2004 | 01:59 PM
but remember, the harder you drive it, and the longer, the quicker the sound's gone, so HAVE FUN!!!
Old Mar 1, 2004 | 04:33 PM
D1NOnly34's Avatar
Thanks for the advice guys, I guess I havent "broken" int eh y-pipe enough, but then again I havent had enough time to do so, cause of my radiator/water outlet problems. Once thats finished, I'm going to drive teh heck out of it. Also, I dont think its the heatshield because I took it off (considering its the one on the cat, right after the ypipe right?). So the heatshield isnt the problem. One mroe thing, how "hard" did you guys drive your cars? And for how long, just wanted to know
Old Mar 2, 2004 | 05:30 AM
bmfjeep's Avatar
Usually it is the stock hanger for the converter that causes the rattle, it gets real close and if you use a flat head screw driver you can pry the fins or tabs away from the converter body and that usually takes care of it.
regards
Dallas
Old Mar 2, 2004 | 09:46 PM
how hard and how long? back roads, 35 mph, trees and ditches on both sides...doin bout 70+ the whole way, for about 15 minutes. lots of fun! be careful!
Old Mar 2, 2004 | 09:52 PM
KFL007's Avatar
Let me know what it turns out to be. My friend has the same exact problem and same situation except his has not gone away for a few months now.
Old Mar 3, 2004 | 08:36 AM
JerzMax's Avatar
I get the same rattling/chatter noise but this started happening after I put the test pipe in. The noise happens only when I let go of the gas in high rmps and going 65+ on highways.
I have a warpspeed y-pipe but it's been installed for almost a year before the noise started. I thought it was the B&M shifter but doesn't seem like it.
Any suggestions?
Thanks ...
Old Mar 3, 2004 | 12:00 PM
Oblongshapes's Avatar
yea they are weird the first couple of days.... i back fired with every gear change.... now its cool
JRod28
Dec 29, 2023 09:56 PM
Starrider
Sep 17, 2015 07:26 AM
Greenmaxspeed
Aug 31, 2015 09:06 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
