stearing wheel shakes above 75mph
Old Mar 1, 2004 | 01:55 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
when ever im on the freeway going at least 75 or over, the stearing wheel shakes really bad. my watch starts flying all over the place and you can see ym entire arm shaking. im on 18's with intrax springs and tokico HPs, and all the tires have the proper ammount of air? is this caused just because of the size of the rims and the suspension setup? thanks.
Old Mar 1, 2004 | 02:16 PM
mymaxlvsattn's Avatar
slackass
are your tires balanced? alignment check? do you have a bent rim?
Old Mar 1, 2004 | 02:21 PM
thekenone's Avatar
definatly try getting them balanced first (cheapest). then look to alignment. imo
Old Mar 1, 2004 | 03:25 PM
Maxima99SE's Avatar
will fly for food
and if that doesnt work....i dunno
Old Mar 1, 2004 | 04:05 PM
95maxcntrljrsy's Avatar
how low are the intrax springs? - also how is your ride with intrax and tokico hp's at like 40-45 bouncy, stiff, or somthing else - do u like it?
Old Mar 1, 2004 | 04:39 PM
Vlasic's Avatar
springs are about 1.7" lower in the front and 1.5" in the back. the ride is really stiff, but i dont mind it cus teh handling is amazing.
they are aligned and balanced as far as i know, but my front right rim does have a crack in it which requires me to re-fill the tire about once a day, but even when the air is fine it still shakes. is that crack the problem?
Old Mar 1, 2004 | 04:44 PM
butchbr73's Avatar
probably...
Old Mar 1, 2004 | 05:56 PM
ohannon7's Avatar
Do you have hub centric rings?? If not i would suggest getting them. I think they run aroun $30, give or take 10??
Old Mar 1, 2004 | 06:30 PM
BRAVO's Avatar
take a look at your lower control arms and tie rods
Old Mar 1, 2004 | 06:47 PM
image's Avatar
Its the Maxima stock bumper etc.... If you get a Stillen or a aerodynamic kit all the lips push the force down... which pushes your car down. The reason you feel it shaking or feeling light is because your car is actually pulling up.
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
