is there an altima.org?????
Old Mar 1, 2004 | 04:00 PM
95maxcntrljrsy's Avatar
someone sold me an altima keyless remote on ebay and told me it was for a maxima (couldnt tell in the pic it was too dark - i trusted a crook) - so im reselling it on ebay as an altima remote (which it truly is) - someone emailed me asking how to program the remote - and id like to see if its the same as maxima or different so i can let the buyer know - thank you
Old Mar 1, 2004 | 04:09 PM
ManualMaxima's Avatar
5th Gen till she dies!
no it is caled altima.net. i am a member!
Old Mar 1, 2004 | 04:15 PM
www.altima.net ? it cant be found
Old Mar 1, 2004 | 04:19 PM
sorry it is http://www.nissantalk.com/forum/
or you can go to altimas.net with an s. got to forums and altima forums.....that forum is *** slow!
Old Mar 1, 2004 | 04:37 PM
straight from my 1999 Service Manual...
1)close all doors and locks
2)Insert and remove the key from ignition cylinder more than 6 times within 10 seconds (hazard warning will then flash) at this time all original id codes are wiped
3)Turn ignition switch to ACC position
4)Flash any button on the new remote control ONCE (hazard lamps will then flash) at this time, new ID code is entered
Do you want to enter any additional codes? (Max of 4)
YES: Release the door lock, then lock again with door lock/unlock switch (in power window main switch) Then Repeat step 4
NO: Unlock driver side door and open driver side door (END) Check operation of remotes
__________________
Old Mar 1, 2004 | 05:27 PM
MadChef's Avatar
I think he meant www.altimas.net
Old Mar 1, 2004 | 05:34 PM
i already corrected myself
Old Mar 1, 2004 | 07:08 PM
MadChef's Avatar
Oops, you did. I was just skimming the thread, so guess I missed it.
Old Mar 1, 2004 | 07:17 PM
Wisky97SE's Avatar
Altimas.net is a fast server . . . I used to post there alot - I had an altima before my maxima.
Turbo1er
Aug 29, 2004 05:01 PM
xsp00kyx
Oct 1, 2002 10:05 AM
xsp00kyx
Sep 30, 2002 03:03 PM
MAXIE
19
May 22, 2002 10:42 AM
