What can I expect for a 1/4 time?
Old Mar 2, 2004 | 09:59 PM
Spaniard's Avatar
Assuming of course that I get a good launch and dont spin.
I will be running about 2850 lbs (no passenger or rear seats and everything else easily removed out of the car)
5lb flywheel
12 lb rims
Bridgestone S-03s 225/50/15 -unfortunately 25 lb tires- good traction for streeties tho
about 18-20 PSI in front tires
MEVI
JWT ECU
96 Octane petrol
Full exhaust (Stillen Y/B/Muffler)
Underdrive Pulley
Hi flow cat
Short thow shifter...
Thats about it... I know most of it is going to be driver ability but I want to know if I drive it right/really well - What can I hope to hit? Just curious to hear what people think... I have an idea of what I would be happy with but want to compare it to the gallery's...
*EDIT* it will be at about sea level around 50 degrees...
Cheers!
Old Mar 2, 2004 | 10:06 PM
DoGGy
17.2 @55 mph
Old Mar 2, 2004 | 10:12 PM
Spaniard's Avatar
Originally Posted by DoGGy
17.2 @55 mph
good one
Old Mar 2, 2004 | 10:22 PM
Dave B's Avatar
Not DAVEB the parts guy
Anywhere from 14.1 to 14.6 depending on your driving skill and the track's available traction. If you can pull a 2.1X 60', you should be looking at lower 14s. If you get 2.1-2.3 60 foots, you should be looking at ~98-99mph traps.
That 5lb flywheel may hinder you though because it will make launching an absolute *****. With 75% less rotational inertia, the VQ will bog off the line if you can't keep the rpms high with a ton of clutch modulation. Light flywheels are good for road racing, but not for drag racing.
Dave
Old Mar 2, 2004 | 10:44 PM
Spaniard's Avatar
Dave
Hmm Err Grrr ARR PFFF Drat! Well, Lets hope I can modulate well cause I sure as heck aint sending the flywheel back! Sounds like I am gonna have alonger learning curve cause of it.
Old Mar 2, 2004 | 11:42 PM
happyricefob's Avatar
V^___^V
don't forget your tirerack sticker, that's like +50WHP!
u will expect low 11 secs
Old Mar 3, 2004 | 05:46 AM
I30tMikeD's Avatar
With those mods, a 2.15-2.20 60' and 50 degree weather should get you low around 14.0-14.2 @98 or so.
mvm062
Nov 30, 2020 09:00 AM
Matt93SE
May 24, 2019 02:58 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
homeyclaus
Sep 3, 2015 06:15 PM
