Clear corners just falling off.
Old Mar 3, 2004 | 09:05 PM
Nismotic's Avatar
Always sunny in philly
The clear corners on my max have just been...falling off. The smaller, non-curved pieces on both sides fell off the first time, so when i bought another set from phenviv, i made sure and DUCT TAPED the inside where they popped on. Guess what? one side has popped off again. Anyone have any troulbe as i have? anythign to remedy this?
Old Mar 3, 2004 | 09:08 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Just take ride to Nissan dealer and buy those plastic pice and replace them.(the white plastic clips)
Old Mar 3, 2004 | 09:09 PM
DAVE Sz's Avatar
Hooooooonda.....
Did you put duct tape on the ball thing? The thing that goes inside the round, white clip.
Old Mar 3, 2004 | 09:17 PM
Maxima99SE's Avatar
will fly for food
when i was taking a road trip my non-curved piece fell out and just hung there... so I just slammed it back into place and when I got home just made sure it felt secure in there and i havent had any problems since then...
Old Mar 3, 2004 | 09:27 PM
cerumo's Avatar
happened to me a long time ago then I use super glue/epoxy, never happen again.
Old Mar 3, 2004 | 09:32 PM
Brudaddy's Avatar
you know the screw that holds it in place? Well, when I changed mine from stock to clears, it would not go back into place. It just kept falling out. All I did was unscrew that screw a couple of rotations(so that it is longer and will stick out further into the bumper) and then bumped the clear corner in. I have not had any trouble since.
Old Mar 3, 2004 | 09:47 PM
DAVE Sz's Avatar
Hooooooonda.....
The screw holds in the big piece, not the small one.
Old Mar 3, 2004 | 09:54 PM
Kanaka's Avatar
i put a dab of hot glue on the plastic plug before shoving the light back in. hasn't come out yet. but i may take out the plastic plug and the metal post and try to secure it from the inside with a regular screw/bolt since clear corners are notorious for walking away when you park your car.
Old Mar 3, 2004 | 10:25 PM
happyricefob's Avatar
V^___^V
1. get on ebay buy another for for like $20
2. duck tape from inside and outside (ghetto style)
3. super glue everywhere in side...it'll be on your bumper permantly (super ghetto style)
4. back to stock corner, JDM style
Old Mar 3, 2004 | 10:38 PM
DAVE Sz's Avatar
Hooooooonda.....
JDM style maxima? right.
Old Mar 4, 2004 | 08:09 AM
Crosse8's Avatar
I put a set of clears on last night, and noticed they did not sit as tight as the Factory ones even with the rubber washer that was suggesed in the install guide. Even using the plastic clip that came in tthe kit of the one from stock lights it still seemed sloppy.
So for the mean time I used a little electrical tape wrapped around the 10mm nut to kind of make them a little more secure, but I was curious as well as to what others were doing to remedy this.
Old Mar 4, 2004 | 09:32 AM
meccanoble's Avatar
Sports Button FTW
i just lost driver side sidemarker doing 90 ish on the highway . friggin sucks.
Old Mar 4, 2004 | 10:04 AM
mrglynis's Avatar
Just securre them from the back. Loosen the plastic guards underneath the car. Reach up under there and screw a bolt into the back of it. You'll need to remove the plasitc clip thats there for the stock lights. You'll probably need a washer. So it'll go like this:
light-car-washer-bolt
Thats should do it. Keep it nice and tight. I havent had any problems.
Old Mar 4, 2004 | 10:35 AM
fast97maxse's Avatar
mrglynis is right
I read about that technique before I put mine on
and did it that way - No problems since install
also good idea cause it makes them harder to steal
lot easier than tape and glue
and if you need to get them off again it isn't such a problem
Old Mar 4, 2004 | 10:48 AM
Tyrexx's Avatar
Mine fell out twice on the highway, it makes such a scary noise like your car is about to crash! turn's out it's just the driver side tiny clear corner piece dangling and smacking up against my bumper, the first time it happened I thought that I broke something in the engine.
Both times it popped out I was doing over 100, Then I just jammed it hard in there now it doesn't do it pop out anymore, lucky me.
Old Mar 4, 2004 | 10:58 AM
vp358's Avatar
Mine were constantly falling out and I was paranoid someone would steal them. I screwed them in from inside the bumper. When my car was lifted for an oil change, I just screwed them in. Now the only way their coming off is if some breaks them or the screw is loosened.
Old Mar 4, 2004 | 11:05 AM
mendon11's Avatar
the only problem with securing them like that is if a theif wants them, he will get them. rather than just easily pulling them out he may rip a hole in the bumper, or if he still cant get them out, may scratch up your car, break a window, etc. just out of frustration. ive seen it happen to people on the org. so if they keep falling out secure them, but if you live in a place where they are stolen regularly, a piece of plastic isnt worth the amount of body work or paint job.
Old Mar 4, 2004 | 11:09 AM
Brudaddy's Avatar
I don't live somewhere where they get stolen easily, so I can't say for that. All I know is I have had mine on there for a while and no problems.
Also, I was talking about the smaller piece(the one on the side, I think...it is the one you have to put in last.) On mine(custommaxima.com), the larger piece screws into the bumper, and the smaller piece is supposed to be screw in from behind like listed above. However, I didn't want to get under there and undo all the underside of the fender well/hood just to screw it in. That is why I said I did what I did. I loosened the post in the clear(it is like a hex, so a socket wrench will do it if it will not move.) a little bit and then just popped it into the stock hole in the bumper. Has been great every since and does not move. (no need for ghetto styles here...you ought to try it...ha ha)
Old Mar 4, 2004 | 11:14 AM
chopperman69's Avatar
I had the same problem on one of mine. I put a dab of silicone on the "stud" and that solved the problem. I was afraid if I bolted them on, someone else might destroy them if they were replacing a bulb or something.
Old Mar 4, 2004 | 11:17 AM
mendon11's Avatar
well when i had mine in i never had a problem with the m falling out. they were a little bit looser than the oem lights but not much. so i just did the old plug & play. no problems. have since taken them out and gone with black tinted to match my car color. looks great
Old Mar 4, 2004 | 12:07 PM
mamasocks's Avatar
It must depend on what brand clears you get. Mine fit just fine in the clips and no problem since. The directions I printed off here said to screw them in from inside the wheel well... I'm glad I didn't try that
Old Mar 4, 2004 | 07:28 PM
Crosse8's Avatar
why did'nt the just make the same dimensions asthe oem lights ? So they would fit the same ?
That is what I dont get ..
Old Mar 4, 2004 | 07:51 PM
Nismotic's Avatar
thanks guys. I didnt want to super glue it, since i might need to unloosen it. No way am i going back to orange corners. I'll just check it out tomorrow. thanks for the responses.
Old Mar 4, 2004 | 07:53 PM
soulrupture's Avatar
Because they don't have to and it's cheaper not to.
I got CustomMaxima's clears and they pop out all the time. I just use one thin clear peace of tape and i don't have to worry.
When ever it rains though I got to add change the tape.
Old Mar 4, 2004 | 07:57 PM
maxima98vspec's Avatar
or u can take ur old housing and use the clear lenses, put them together and just paint the inside chrome or something...............
Old Mar 4, 2004 | 08:47 PM
mendon11's Avatar
i dont think you can do that....
Old Mar 4, 2004 | 09:05 PM
ch13f's Avatar
I put a small piece of double sided foam tape on the "ball" that fits into the socket in the bumper, it's been fine ever since. Instead of just poping out, you need constant pressure in order to remove them.
Old Mar 4, 2004 | 09:45 PM
moose54's Avatar
do what brudaddy says it works great U can even leave the original plastic clip on with the ones I got of ebay, You hear them snap right in.
Old Mar 4, 2004 | 09:51 PM
i think it could...i was talking to a guy earlier while he was comparing the two cause he had the same problem and he said it could
Old Mar 4, 2004 | 11:45 PM
007max's Avatar
when i first put mine on i didn't put that plastic ball / clip thing on for the smaller light and it poped out while i was going 85 on the freeway. that scared the **** out of me it was so loud. i thought i hit something and massively screwed up the car because it was banging against the fender as i was driving. so i pull off to see wtf and its just that little light hanging there. i felt so stupid ! well i got home, pulled the plastic **** thing off of the oem light and put it on the new ones and i havent had it happen since
gavin68
Sep 18, 2021 12:36 PM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
