For the last time...Warspeed vs. Budget y-pipe...what's better???
Old Mar 4, 2004 | 05:18 PM
  #41
Jime's Avatar
Originally Posted by nismos14
i guess its just steel then? cuz its definately not stainless
Well I am not going to argue with you but Budget does NOT make anything but Stainless Steel pipe and have not made an aluminized pipe in over 2 years.
The flanges are mild steel because of warping etc but piping is all T-304 Stainless Steel.
Old Mar 4, 2004 | 05:24 PM
  #42
nismos14's Avatar
§è~® f®ÈÄk
i believe you i just know it wasn't stainless steel that i recieved, i'll get a pic and show ya all what i got.
Old Mar 7, 2004 | 06:42 AM
  #43
nismos14's Avatar
§è~® f®ÈÄk
what material is this test pipe? whatever it is, is the same exact material my y-pipe was, i got them at the same time from budget and this is the test pipe i bought from them and got at the same time as the y.
Old Mar 7, 2004 | 08:02 AM
  #44
Jime's Avatar
You can't tell what its made out of by looking at it. SS does not come polished it looks a lot like regular mild steel unless you really know what you are looking at. If its uncoated you can usually see the grade printed on it as well.
Use a magnet, that will tell you if its SS or not. A magnet will not stick to SS unless its a very low grade with more carbon steel in it.
Old Mar 7, 2004 | 08:14 AM
  #45
RastaManMax's Avatar
Originally Posted by Dave B
I live in the Midwest also and my 2.5 year old alumnized WSP pipe doesn't have a spec of rust on it. Don't forget that stainless can rust too. Budget doesn't use a terribly high grade stainless.
Dave
How is Budget's T-304 SS any worse than Warpspeeds T-304 SS? If most Canadians are using Budget without problems, it says something about them, their steel and quality must be high. I'd go budget just because it's cheaper than WSP for SS, other than that the performance difference and 'build quality' is negligable.
LEMAR
Old Mar 7, 2004 | 08:25 AM
  #46
Jime's Avatar
T-304 is produced to ASTM standards the composition etc cannot be compromised or it will not be passed and stamped by them.
This is from: http://www.stainless-steel-world.net/duplex/grades.asp
This is the standard for T-304
Stainless Steel - 300 Series Grade(UNS Designation) End Use Composition nominal wt% Specifications Density lb/in3 (g/cm3) Tensile Strength ksi. (MPa) 0.2% Yield Strength ksi. (MPa) Elongation % Hardness
304
S30400
Sanitary, Cryogenic, and Pressure-containing applications, Home and commercial appliances, Tank structural parts and processing equipment C .08, Mn 2.0, P .045, S .03, Si .75 Cr 81-20, Ni 8-10.5, N .10 ASTM A240 ASME SA-240 .285
(7.9) 75
(515) 30
(205) 40 92 Rb
Old Mar 7, 2004 | 08:26 AM
  #47
nismos14's Avatar
§è~® f®ÈÄk
oh ok i didnt know that i'll have to check the magnetic test thanx jime!
Old Mar 7, 2004 | 08:28 AM
  #48
Jime's Avatar
BTW the flanges will be mild steel so you can use that as a yardstick to compare with the pipe.
Old Mar 7, 2004 | 09:01 AM
  #49
Doc's Avatar
Doc
Thats $250 Canadian which is $185 US. Budget call it an F because it looks more like an F than a Y, regardless thats it.
If you call, tell Jody that Jime sent you.
Recently I inquired about the Canadian-US currency conversion and was told that $250 Canadian translates to $200 US, not $185.
Old Mar 7, 2004 | 09:12 AM
  #50
Jime's Avatar
Well that was on the 4th of Mar, today its 189.60.
Last year it was $160, it changes daily.
Currency conversion results
Date: 250 in Canadian dollars equals: Exchange rate:
05 Mar 2004 189.60 US dollars (noon) 0.7584 (1.3186)
If you want to check go here.
http://www.bank-banque-canada.ca/en/exchform.htm
Old Mar 7, 2004 | 09:20 AM
  #51
Doc's Avatar
Doc
True that on the daily change. I had checked it just a few days ago and it was much different. I guess ya gotta keep your eye on it daily and pick your spot to order. Thanks, man.
Old Mar 7, 2004 | 10:44 AM
  #52
dr_blaqueman's Avatar
I have a WS
thatcollegestudent
18
Oct 5, 2015 02:29 PM
