i cant get off the clearance light
Old Mar 14, 2001 | 12:52 PM
VQracer's Avatar
in the owners manual it says to take off 1 screw on top, ok i did it, then place cloth between headlight and clearance light and place a screwdriver in to pry the light out. i tried it but it is very hard. is there only 1 screw? the top of the clearance light seems to be loose but the bottom is stuck like supaglue. so how do i get it off?
Old Mar 14, 2001 | 12:54 PM
breaux124's Avatar
http://www.bol.ucla.edu/~cchiu1/corners.html
Old Mar 14, 2001 | 07:29 PM
98BlaximaSE's Avatar
I had this prob before. If you look at the inside lower half of hte light, you see a ball and socket joint, thats what holding it in. Now all you have to do is stick a flat headed screw driver in and turn it. that should force the socket out. And the light should then come out easily.
Old Mar 14, 2001 | 08:12 PM
Nathan's Avatar
You can try spraying wd40 on the ball and socket which might help.
CheshireCat76's Avatar
Just make sure...
That you spray some WD-40 on the ball & socket joint.
It makes popping those lights out a lot easier.
lowpost99
Oct 26, 2025 06:53 PM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
